Question about Lexmark X364dn All-In-One Laser Printer
HOW TO CHANGE PHOTOCONDUCTOR KIT LEXMARK X364DN?
  • 14 Answers
SOURCE: Resetting Lexmark E340 after replacing photoconductor kit
Reset Procedure(s) after installing new photoconductor kit
Resetting the Lexmark E340/342 (display type) machines
1) Turn the printer off
2) While still off, press and hold the SELECT and RETURN buttons.
3) Keep both buttons pressed, and turn the printer on. Continue to hold both until either “Performing self test” or “Config menu”
appears on the display.
4) Release the two buttons
5) RESET PC CNT should now show on the display. If it does not, press the left or right menu buttons until it does.
6) Press the SELECT button once. “Resetting PC Cnt Value” should show on the display.
7) When the display shows CONFIG MENU again, turn the printer off.
8) Turn the printer back on. (Do not hold any buttons down this time). The printer is reset.
You can confirm the counter was reset by printing a “menu settings page”.
Posted on Oct 24, 2008
MrNutz
  • 9 Answers
SOURCE: I have a lexmark e250dn
Here is how to reset the photoconductor kit counter:
1. Make sure the new kit is installed and the printer is turned ON.
2. Open the front panel.
3. Hold the Cancel button in until the front panel LEDs flash.
4. Close the front panel
Posted on Mar 26, 2009
  • 1684 Answers
SOURCE: problems after changing the photoconductor kit
Here are the steps to rest the phooconductor unit.
Entering Configuration Menu
1. Turn off the printer.
2. Press and hold Select and Return.
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
To reset the counter:
1. Select Reset PC Cnt from the CONFIG MENU.
2. Press Select to reset the counter to zero.
Note: Permanent page count is not affected by this operation.
I hope this helps,
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Posted on Jun 21, 2009
YourZEN
  • 820 Answers
SOURCE: Can you provide a copy of the instruction sheet
Instruction sheet photoconductor kit for Lexmark E250D on this page:
http://support.lexmark.com/index?page=content&segment=DOWNLOAD&locale=en&userlocale=EN_UK&id=HO2997&productCode=LEXMARK_E250D&actp=TOP_DOCS
Posted on Sep 14, 2009
Testimonial: "The instructions worked perfectly; thanks so much for your help."
techbuster
  • 5081 Answers
SOURCE: How do i reset the counter for a Lexmark e260d
After replacing all the items in the photoconductor kit, reset the maintenance counter: 1 Press and hold the Select and Return buttons while you turn the printer on. 2 Release the buttons when Performing Self Test appears on the display. The printer performs its power-on sequence, and then Config Menu appears on the first line of the display. 3 Press Menu until you see Reset Maint Cnt and then press Select. Reset appears on the second line of the display. 4 Press Select. Resetting Maint Cnt Value appears briefly on the display, and then is replaced by Config Menu on the top line and Reset Maint Cnt on the second line. 5 Press Menu until you see Exit Config Menu, and then press Select. Activating Menu Changes appears briefly, followed by Performing Self Test. The printer returns to the Ready state.
Posted on Dec 02, 2009
What does PC Life Warning mean?
You get the PC life warning when the photoconductor kit is near exhaustion. You have to prepare are replacement.
Please click on the link below to get instructions on how to reset pc count. Whenever you install a new photoconductor unit, you must also reset the page count on the printer.
http://bitly.com/rgOZIm
Aug 02, 2011 | Lexmark X364dn All-In-One Laser Printer
I replaced my photoconductor and now my printer won't print. The toner button and ! button flash.
The photoconductor kit's drum is full and needs replacing. The printer will not print any more pages until the photoconductor kit is replaced.
Click on the link http://bit.ly/oD75Kw to see instructions on to replace photoconductor.
For further assistance, please contact Lexmark Technical Support
Jun 06, 2011 | Lexmark E232 Laser Printer
My lexmark e120 in the setting page indicate replace photoconductor and this is new.
The replacephotoconductor message should be cleared only when the photoconductor kit has been replaced. If PC kit is new and still getting samemessage, please reset the photoconductor counter to zero. For further assistance,please contact Lexmark Technical Support
May 03, 2011 | Lexmark E120 Laser Printer
Replace pc unit problem on Lexmark W840 Laser Printer
Here is an excerpt I found from the W840 user manual. Looks like you need to change the photoconductor kit. Here is the link for the user manual: images.lexmark.com/publications/pdfs/w840/eng/ug.pdf
To ensure print quality and to avoid damage to the printer, the printer stops operating after the photoconductor kit has reached approximately 60,000 pages (Letter/A4). The message 84 Replace PC Unit is displayed when the printer reaches this point. If the Toner Alarm setting is set to Single or Continuous (default is Off), the printer automatically notifies you before the photoconductor reaches this point and displays the message 84 PC Unit Life Warning. To avoid having the printer stop operating, replace the photoconductor kit when you first receive the 84 PC Unit Life Warning message. Once the photoconductor kit has been replaced, normal printer operation resumes
Apr 11, 2011 | Lexmark W840 Laser Printer
Lexmark E450dn Error msg 84 Replace Photoconductor Photoconductor has been replaced same error msg. Is there something else to look for?
No, if you changed the photoconductor kit, then you just need to reset the maintenace count for the PE Kit.
Please follow this hyperlink to the specific instructions you need on Lexmarks web site.
http://support.lexmark.com/index?page=content&id=HO3155&locale=EN&userlocale=EN
they are easy to follow directions and you should have no problems.
Thanks
Jan 10, 2011 | Lexmark E450dn Laser Printer
Clear photoconductor counter Printer Lexmark e342n
Here's an article on How to Reset the Photoconductor Page Count on a Lexmark E340 or E342. Click on this link http://bit.ly/b1Qil7. Thank you for choosing Lexmark.
NOTE: Resetting photoconductor page count should be done only when a brand new photoconductor kit is installed. Doing so without replacing pc kit could cause print quality issues.
Sep 15, 2010 | Lexmark E342n Laser Printer
How do I install a Lexmark E352DN Photoconductor
Here's an article on How to Change the Photoconductor Unit/Kit on a Lexmark E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/aykTXL. This should give you an idea on how to install the photoconductor unit in the Lexmark E352dn printer.
NOTE: If you are replacing your old photoconductor unit with a new one, after installing it you will need to reset the photoconductor counter as well.
Aug 12, 2010 | Lexmark E 352dn Mono Laser Printer
Printer is telling me that the life of photoconductor kit has reached the end of its useful life. i have changed the kit with lexmark brand cartriage and will still not work
After replacing the photoconductor kit, you will need to reset the photoconductor page count. Here's the link for instructions on how to reset the page count: http://bit.ly/agYtVo . Or simply press and hold the CANCEL button while the printer is on and the front cover open until all lights are flashing. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Jun 17, 2010 | Lexmark E232 Laser Printer
Lexmark E238 Laser Printer
Here are the steps to reset the page count on a Lexmark E234, as described here:
  1. Power the printer on and get it to the Ready state.
  2. With the printer on and in the Ready state, open the front cover.
  3. Press and hold the Cancel button until all of the lights begin flashing up and down.
  4. Release the Cancel button and close the door. The photoconductor count should now be reset.
Hope that helps!
-MetaB
Aug 12, 2007 | Lexmark E238 Laser Printer
Lexmark X364dn All-In-One Laser Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
