Phillips DVD3365 dvd recorder shows blocked, the tray opens and closes but the DVD doesn't spin
2 Suggested Answers
SOURCE: dvd tray will not stay closed. opens and shuts randomly
i had exactly the same problem on a LG-RH278H resp. a Medion MD 81733. I solved it by opening the micoswitches, cleaning the contacts and streching the springs inside the switches a little. The Problem was, that one of the microswitches stayed conductive even when it was off/open.9acead3.jpg
Posted on May 22, 2009
Panasonic DMRES15 DVD Recorder disc not spinning
Troubleshooting Solution
1.Display Message " Please wait" Not
booted
2.DVD-Rom Two-Three times make noise but doesnt spinning
3. Doesn't
open tray, No video OUT
1.Bad Main Board VEP79117
2. Bad DVDROM
3. Bad Prosessor
PCB
Mar 16, 2013 | Panasonic DMRES15 DVD Recorder
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
Open top Cover of drive, open tray, close tray.
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Have panasonic dmr-ez485v error message -NO READ- changed disks used prerecorded movie same as my recorded disks, hit reset - still no change
I just saw the date on this message and realize that it was awhile ago. I assume that you have dealt with it by now... So for others who are trying to fix their DVD player:
I have a DMR-EZ485V DVD player and just started getting the error message "No Read." I couldn't find an answer on the internet and finally called Panasonic's customer service, (there is no charge 1.800.211.7262). Since it says "No Read" to everything--store-bought DVDs, burned DVDs, CDs; AND when there is nothing in there (it acts like it is trying to read when the tray is empty), the customer service rep thinks that I am having a lens issue. It either needs to be cleaned (can pick-up a product at Best Buy or Radio Shack) or, if that doesn't work, the lens needs to be replaced.
Aug 09, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Shows Open when closed and vice versa. Tries to
The tray orientation may have gotten messed up. Try opening the player and then unplugging it, closing the tray with the unit powered off and then turning it back on.
Jan 06, 2010 | RCA DRC8295N DVD Recorder/VCR
The tray on my Phillips DVDR 3380 won't open. It says blocked or no disc. I have pressed open /close many times but to no avail.I have turned the power off, makes no difference. I have press stop when it...
I have the same problem. What I do is push my hand down firmly on top of the DVD Recorder above the tray and while doing this press the open button. If this doesn't work get a screwdriver and poke it into the sides of the tray and pull it away. I find that the first method works best! XD
Hope This Helps!
Jul 04, 2009 | Philips DVDR3380/05 DVD Recorder
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
I have a phillips DVD recorder DVDR3350
my dvd recorder has the same problem press the open/close button if this doesnt work when you press open again try hitting it very lightly on top as that is what i have to do to mine to get it to open sometimes
Dec 14, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
