Question about EliteGroup P4VMM2 V7.3 (P4VMM273) Motherboard
3 long beep and no post
Just got a board from my niece, it emits 3 long beep and pause for a few seconds then repeats the cycle on and on. i tried cleaning the ram and it did not improve the situation.trid also replacing the ram, with the same results. do you think had it already , what other things should i do to fix this, thanks in advance
  • 1 more comment
  • buddy3388 Jun 23, 2009
    I used 2 pc266 and pc333 512 mb. both are good and working
    its a kingston ram and it is listed in the vendors list
  • buddy3388 Jun 24, 2009
    its a ecs p4vmm2 ver 7.3
  • 102 Answers
Are you sure its the right ram for that mother board?
Posted on Jun 23, 2009
  • 1 more comment
  • bassass Jun 23, 2009
    that doesnt mean there the right ram for that mother board..... most times when it beeps it means some thing isnt right
    ok what kinda mother board is it...?
  • bassass Jun 24, 2009
    from what im seein ..this is what u needhttp://www.4allmemory.com/index.cfm?fuse...
When push start button goes right to no spin and turns off
As for unplugging it, I had an issue with mine not spinning on the Perm Press cycle. I tried unplugging it for an hour and plugging it in again to no avail. Just gave up on the Perm Press cycle. A few months later I unplugged it for a week while I was on vacation and low and behold, it started to spin on the Perm Press cycle! I'm not sure how long it would have needed to be unplugged, but you may want to try for a couple of days. But, in the mean time....
Try running the diagnosis and looking for an error code.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed. A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
For complete instructions and to run a more thorough diagnosis, download the instructions here:
http://manuals.frigidaire.com/prodinfo_pdf/webster/134542000.pdf
May 10, 2015 | Frigidaire GLTF2940ES Front Load Washer
Xpc sg33g5 shuttle. I turn it on 3 seconds later turns off then powers itself back on and repeats. Why is it doing this? Please help
It's not passing post. Start by removing and reseating the ram, cpu, front panel connections, PCI devices etc... ONE AT A TIME to see if that helps. Also, if your board came with a small black speaker, make sure that is plugged in because most motherboards will emit a series of beeps that you can use to help you troubleshoot.
GOOD LUCK!!
May 20, 2014 | Computers & Internet
Frigidaire front load washer. E46 error. replaced control board. Still have same error code. Is there a way to clear the error code and reset the washer with the new board?
Hello CJ Lou - Typically that is correct, error code E46 indicates to replace main control board. First, either unplug or flip the household circuit breaker off to the washer to reprogram it. Wait approximately ten minutes and restart unit. Then try pressing and holding the START and PAUSE/CANCEL buttons simultaneously. All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the START and PAUSE/CANCEL buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify the correct error codes. If it proves to be ineffective, contact a professional to accurately pinpoint any potentially more serious issues.
Jan 30, 2013 | Frigidaire ATF6000ES Front Load Washer
It tries to start but then the start light keeps flashing
Hello John Schmader - Sounds like the washer could be experiencing a communication error with main control board, faulty door lock assembly, pump or the timer itself is not operating correctly. Is the unit making a humming noise? If so, either the drain hose or pump is clogged and needs to be cleaned. Does the washer display an error code? Try pressing and holding the START and PAUSE/CANCEL button simultaneously. All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the START and PAUSE/CANCEL buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify an error (if one displays).
Jan 26, 2013 | Frigidaire GLTF2940ES Front Load Washer
F8 error code Whirlpool Duet
see this causes and fix it. See yur section troubleshooting in your owner manual, or call some tech.
F8 Board failure Replace control board (also called ERC or clock).
Sep 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
What wrong when washer machince stop in the middle of cycle and leaving water inside make humming noise read err
Wait 5 seconds
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
you may also have a code such as E47 or E24 etc..
Comme back with the code and I will explain what is the meaning of the code
Nov 28, 2011 | Frigidaire Washing Machines
Machince stop in middle of cycle leaving water inside make humming noise
Wait 5 seconds
Nov 28, 2011 | Frigidaire GLTF2940ES Front Load Washer
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
3 beeps after shut off.
Sounds like a shorted key fob or intermittent BCM problem.
Aug 05, 2009 | 2006 Saturn Aura
Computers & Internet Logo
136 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
