Question about QNAP NAS Servers TS-412-US TS-412 Turbo NAS - NAS Server
Qnap nas error 0x80070057 - QNAP NAS Servers TS-412-US TS-412 Turbo NAS - NAS Server
How to fix Windows Live Mail Error ID 0X80070057?
Please read this thread as it answers your question ...
https://answers.microsoft.com/en-us/windowslive/forum/livemail-email-send/windows-live-mail-error-id-0x80070057/a063f0fd-e8e6-46b3-bd1f-6baad72daa0c
Apr 03, 2018 | Computers & Internet
Error 0x80070057
problem your os please
Jul 25, 2014 | HP LaserJet 1320n Printer
How to fix error 0X80070057 on HP Pavilion Slimline s3323?
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
To fix 0x80070057 errors you need to follow the steps given below:
Update Windows driver:
An obsolete driver can be one reason for causing this error problem.
Therefore to remove 0x80070057 errors message from your system you need to update your Windows driver.
For that you must
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html also
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
Registry repair: Corruption to the registry can cause 0x80070057 errors to appear. Registry is the storehouse of files and program settings. Therefore frequent access to the registry key can cause corruption to it. Therefore you need to to repair the
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
registry. also http://download.cnet.com/ccleaner/
If the error problem still remains in your system then it is recommended to
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
It might be possible that due to virus or malware has infected your system that's causing 0x80070057 errors.
The anti spyware software will remove the viruses and make your system clean.
Hence increases the performance level of your system.
all of this is freeware
hope this helps
if there are any stubborn drivers
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
http://www.downloadcollection.com/device_doctor.htm
Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use
Sep 20, 2012 | HP Pavilion Computers & Internet
Error 0x80070057
You can use your original Windows 7 Ultimate installation DVD as a Recovery Disk if you have one, alternatively, you can download a copy of an official Microsoft Windows 7 Ultimate 64bit DVD .ISO disk image from the following URL.
http://msft.digitalrivercontent.net/win/X17-24395.iso
Note: The above download image is 3GB in size and may take some time to complete depending on the speed of your internet connection.
For those looking for download links for other versions of Windows 7 these links were published on the AskVG web site a little while back and include .ISO images inntegrated with Service Pack 1.
If you are having problems when burning an ISO image to DVD media that is giving the 0x80070057 error, then you may have a device driver issue as that seems to be a common cause of such errors.
You could try using a free third-party CD/DVD burning utility such as CDBurnerXP which works fine on Windows 7, Vista or XP.
Dec 24, 2011 | Microsoft Windows 7 Ultimate for PC
Getting write-protect error on qnap ts110 folder
right click on the folder select properties thwn click the sharing tab make sure the folder is sharing and the box is not ticked make this folder private in xp
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
Remember do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Jul 03, 2011 | QNAP Systems TS-110 QNAP Turbo NAS, USB...
Error 0x80070057 the parameter is incorrect
http://www.wiki-errors.com/wiki-errors.php?wiki=0x80070057.explains all and how to fix.
Jun 13, 2011 | Computers & Internet
Error 0x80070057 the parameter is incorrect when coping iso/cso files
problem during copy mp4 file to mobile memory media through data cable error 0x80070057 the parameter is incorrect
Sep 14, 2009 | Microsoft Windows Vista Home Premium with...
QNAP NAS Servers TS-412-US TS-412 Turbo NAS - NAS Server Logo
Top QNAP Computers & Internet Experts
David Payne
David Payne
Are you a QNAP Computer and Internet Expert? Answer questions, earn points and help others
