Question about Neff 24 in. S5555X0GB Built-in Dishwasher
Switched itself off mid cycle and display off then on
Mid cycle it switched off and display gone, after 30mins of push on/off button it came back on. Now can't get it to switch on or display
2 Suggested Answers
jonniewalker
  • 1029 Answers
SOURCE: The door will not close. It appears that the lock
Check for obstructions, Check the door latch the latch may have moved into its housing,use a screw and position the door latch properly free from any obstruction,then try closing the door again..if not then you may need to replace the door.hope this helps pls do let meknow
Posted on Apr 05, 2010
Drawer stopped mid cycle
Have you tried to turn the mains power switch off and on to see if it resets the drawer to off state. Need a bit more detail of what you see on the display etc. when you try to turn back on.
Dec 10, 2012 | Fisher and Paykel 23 in. DD-603 Built-in...
Washer stopped mid cycle w/ water...mid agitation.
Might just be a bad lid switch. Push down on lid or switch.
Jan 12, 2011 | Whirlpool LTE6234D Top Load Stacked...
Kenmore disposal hums, nothing jammed, everything moves freely, but wont spin. reset button stays tripped & wont catch
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Apr 03, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
LG WM2233H stop worrking in mid cycle, no displya
This has happened to me when the power has gone out. It doesn't display anything and all you can do is restart the cycle.
Jan 17, 2010 | LG WM2487H Front Load Washer
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Opened dryer door mid-cycle left open 1 hr. Dryer won't restart
there is a door switch on left upper corner of drier opening, make sure the little prong is clicking when you push it in. this turns the drier back on when the door is closed and the start button is pushed.
Dec 31, 2008 | Kenmore 63942 Dryer
Washer keeps stopping mid cycle
Bad timer motor or mechanism...accordianman
Mar 21, 2008 | Dishwashers
Neff 24 in. S5555X0GB Built-in Dishwasher Logo
20 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
