Question about Sewing Machines
The balance wheel is not working? why is that ?
  • 980 Answers
You need to give more specific information
Posted on May 27, 2014
I have a Singer 99-13 with knee control. I wound bobbins but can't get it to sew. Is there something that turns it over to sewing? Thanks. Karen
On the 99-13, you wind the bobbin with the balance wheel in the stop motion position. Thus during bobbin winding, the needle mechanism is disconnected from the rest of the machine. You probably need to tighten the set screw on the balance wheel. The screw is in the center of the balance wheel on the right hand side of the sewing machine. Hold the balance wheel while you turn the screw away from yourself. (You hold the balance wheel and turn the screw over towards you for winding.)
The manual for the 99-13 is available from Singer on their manuals page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/9d4377811af9ffbbaa1b8efd50ea962c142a66d9.pdf . Look at figure 5 on page 7 (page 4 of the PDF) and then page 10-11 (page 6 of the PDF) for the bobbin winding directions.
I hope this helps.
Jan 02, 2017 | Singer Sewing Machines
Tip
Sewing machine balance wheel stops.
Hold the wheel with one hand, turn the stop motion screw towards you. Place both feet upon the treadle and turn the balance wheel towards you at the same time allowing the feet to move freely and lightly with the treadle. Continue this until everything moves freely and easily. Do this until the machine can re-start without the balance wheel turning in the wrong direction.
Then tighten the balance wheel. Then place cloth under the presser foot then lower presser foot with the lever.
on Jan 18, 2010 | Sewing Machines
How do I get the wheel off an old Singer sewing machine model 66
If you are talking about the Balance wheel on the od Singers it is fairly easy.
You first need to remove the small screw in the clutch ( which is the chrome knob in the middle of the balance wheel) Once this is removed you can completely unscrew the clutch and then remove the balance wheel
Sep 16, 2014 | Sewing Machines
Balance wheel doesn't turn
Don't force it. open up under the presser foot and the bobbin area.... pick out any threads.
Sep 01, 2012 | Janome L-344 Mechanical Sewing Machine
Error code 6 (thread in motor but there is none)
If you can turn the balance wheel by hand and the needle goes up and down it may be loose belts, if you can't turn the balance wheel by hand then there is definitely thread stuck somewhere in the raceway
Jun 24, 2010 | Brother CS6000i Computerized Sewing...
The hand wheel keeps falling off and now when i try the sew nothing happens, the needle does not move. all i hear is the sound ofthe motor but nothing happens
If the balance wheel is coming off which it should not do because it is held on by the belt then you have not tightened the stop motion in the middle of the balance wheel, make sure you have not lost the little screw in the middle if the balance wheel.
Feb 15, 2010 | Sewing Machines
Singer 328k bobbin winder replacement
Follow these instructions, undo the 2 screws on the right hand side plate where the balance wheel is and take the plate off, undo the screw on the chrome stop motion wheel, undo the stop motion and take it off, take off the 2 pronged washer and notice which way it goes on, not a problem if you can't remember, you should be able to pull the balance wheel back so you can get to the screws on the winder, if you can.t and if you have a problem getting the balance wheel all the way then go the very bottom of the machine and you will see 2 big holes and one of the holes will lead you to a big screw and nylon adjuster, slacken the screw and move the nylon adjust so the belt goes slack, you can not take the balance wheel all the way off to get to the screws on the winder, take the old one off and screw the new one on, whilst you have the balance wheel off it would be wise to put some thin oil on the shaft before you put the balance wheel back on, when you have the balance wheel on and the and the belt round the pulley turn the nylon adjuster so the belt is tight and tighten up the screw, put the side plate back on, put the 3 pronged washer back on, put the stop motion wheel back on and just tighten finger tight then tighten the small screw.
Nov 22, 2009 | Singer Sewing Machines
Balance wheel on sewing maching does not turn
hi have you recently refill bobbin seems like you need to reengage clutch tighten inner wheel on hand wheel or slide switch depending on machine refer to your manual good luck
mary h
Dec 27, 2008 | Sewing Machines
Balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
Apr 26, 2008 | Brother NX-400
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
