How can i put in a new pin? - Computers & Internet
After I put in the puk it asks for a new pin. what is the new pin?
new pin means to set a new pin that only you know... nobody else..
youu can set at least 4 digit...
thank you. :)
Dec 19, 2016 | Cell Phones
I put the PUK code. Then I put new PIN. Then I put to verify the new PIN. Then it says: "Code Error"
PUK and PIN = two separate things
PUK = Personal Unlocking Key. Supplied by your cell phone provider as the people who own the phone under an unexpired contract.
PIN = Person Identification Number. The number you use to keep your phone locked and private.
If the phone is stolen the cellphone carrier locks it with a PUK so it can't be used unless the person who has it contacts them. Also the phone is locked if a user tries 4 times unsuccessfully to open a phone using the wrong PIN Number. You can only open it with a PUK code.
Click on my name, click on TIPS, click More, click Cellphones, read my article on PUK codes.
Jun 17, 2016 | Nokia 2600 Classic Cell Phone
How do i enter a new pin
Go into menu then settings and find security settings . Go to section that says change pin you put in your old pin . You should be able to put a new pin in then you reenter the new pin then click ok . Or save changes . You will get a message saying your pin has been changed just ignore it
Aug 14, 2014 | Cell Phones
How do you replace the chain tensioner on a Razor E300
Theres an 8mm nut holding it onto the pin that goes thru the frame.
Take that nut off and remove the tensioner. Put some grease on the new pin where the tensioner goes. Put the end of the new spring into the hole in the frame next to the pin hole. Hold the tensioner in place and put the pin thru and the nut back on. You should be able to get the chain back on the sprocket without loosening the axle nuts. Hope this helps.
Aug 03, 2014 | Razor E300 Scooter
How to remove door bushings
The only door bushings I am aware of are the ones on the hinge pins. Correct? If not, please clarify what you mean.
New pins come with new bushings, and the hinges are welded on so the pins are pretty much the only items replaceable. Not a fun job - because of the door stop springs you will need a spring compressor, and you will also need a special tool to drive out the old pins. However, both are available from a parts store or Amazon.
Just open the door and support it from the bottom, and then go for it, one pin at a time - for the upper pin, compress and remove the small spring, drive out the old pin, drive in the new pin and put the spring back. No spring on the bottom hinge - just replace the pin.
Apr 02, 2014 | 2000 GMC Jimmy
Door is to low when you close it. Are to hinges welded on
you need new hing pins and bushings. easy fix. just pop out the old pin put new bushings in and put new pin in. place a jack or stand under door when removing pin.
Jan 04, 2011 | 1997 Dodge Dakota
How Do I Unlock My Pin Or Puk Code On My phone i put in the puk and then it tells me to put in a new pin and when i do put in a new pin when i try to verify my new pin code it says code error
Please call the customer care of your network operator, they will tell you the unlock code for free. We can't unlock it anyhow. Please note, that you don't enter any random numbers, it'll damage your sim card permanently. Good luck. Thank you for using FixYa.
Jun 02, 2010 | Nokia 5310 Cellular Phone
PUK /PIN
if you put pin wrong 3 times the puk comes, if you put puk wrong too many times it makes the sim card useless. to get the correct puk code call your phone service provider they are the only ones who have it.
Jun 08, 2009 | Nokia E71 Smartphone
My PIN has been blocked
try to reset the phone
then try the code
it will work
Mar 23, 2009 | Nokia 6288 Cellular Phone
PIN Code
the defult pin for the ks360 is 1111
Nov 17, 2008 | Lands Phones
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
