Question about OKI C9600n Led Printer
Fatal error 175?
On the screen it says Fatal error 175. recetly ato change the drum K- which we did..now the error came.please help
JayBlair
  • 328 Answers
SOURCE: Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Posted on Aug 10, 2007
  • 11 Answers
SOURCE: fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Posted on Jan 11, 2008
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: SERVICE CALL ? 980 ? Fatal Error
I was able to reset my Fatal Error 980 code on my C5800. There is only two wires coming from that connector and not four at the bottom of the fuser. That is pin 2 and 3. 4 and 5 is still the fuse but there are no wires there, just the 2 pins. What you have to do is make a fuse by connecting pin 4 and 5 together with a piece of wire and break the wire after a few seconds after powering up. This will reset the Fuser counter back to 100%. DO NOT DO THE NVRAM RESET, THAT WILL ERASE YOUR NETWORK FEATURE. Here is the step by step of what I did.
1)Take out the Fuser and lay the two blue levers flat and remove them.
2)remove the two silver screws and separate the casing.
3) Remove the two black screws from the connector at the bottom of the fuser closest to the edge.
4)Unravel and loosen the wires so you can pull that connector out a few inches so you can get a couple of wires in there. You will see what you need to loosen to get the connector out far enough, really easy.
5)Insert a wire into each of the two holes on the back of that connector. Its pretty simple to see where they go, 2 and 3 have wires going in, 4 and 5 dont which is the fuse. After you get the wires in the 2 holes, check for continuity from the end of the wires and the terminals if you can. Make sure the wires are long enough to hang out the case. Use the thinnest wires you can find.
6)Run the wires out of the case and put the case back together and put the fuser in. Twist the two wires together and power up the machine. As soon as you here the first motor,which is about 5 seconds, pull the wires apart and BAM, you just reset the fuser back to 100% and cleared the "980" Fatal Error. You could always put a miniature fastblow fuse in instead of using the wires but that would be tedious to me.Good luck
Posted on Jul 12, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
Getting error 142 fatal error
unplug the unit then clean the printer and all drum units and etc with compressed air. Replace the drums and replug should solve the problem.
Dec 10, 2009 | OKI C5500n Printer
Oki c9600 fatal error 175 ?
Error 175
Fuser Thermistor
short-circuit or Open
is detected (High
Temperature (HOT)
or Low Temperature
(COLD))
Turn ON power again.
Leave in that state for 30
minutes then turn ON power
again.
Dec 06, 2009 | OKI C9600n Led Printer
Iomega Screen Play HD showing fatal error 05 -
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Sep 25, 2009 | Iomega ScreenPlay
Iomega HDD Fatal Error 05
Jul 05, 2009 | Iomega ScreenPlay
Okie C5400 giving 162: Fatal Error
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
Fatal error 141
141 Drum Up/Down, Color: Magenta An error has been detected in your printer's Magenta Drum. Did you already get this fixed?
Jun 04, 2007 | OKI C7300 Led Printer
Fatal error
Fatal Error K (for BLACK) - Black toner or drum problem, Drum life exceeded? Display would of said black drum near life before failing.
May 15, 2007 | OKI C5100n Laser Printer
OKI C9600n Led Printer Logo
21 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
