Question about Toshiba Satellite Pro 4600 Notebook
How do i go into the bios setup f12 or what? I hit f12 at startup and it ask for a bios update diskette.
  • Patrick Kam May 11, 2010
    To get into BIOS, it may be [F2] instead of F12.
    Some silly manufacturer even put F8 to get into BIOS, making Boot to Safe mode very hard.
  • 55 Answers
You better do a flash Bios update via internet....
Good Luck
Posted on Jun 23, 2009
How i can enter in setup bios of acer, model aspire M1641
I couldn't find the manual but generally at startup on the screen briefly will be which key to hit to enter BIOS. Often it is F2, F12 or DEL
Sep 15, 2010 | Acer Aspire M1641-U1521A PC Desktop
Hit what key to get into bios? are there restore keystrokes to restore?
Usually, for Compaq laptops, they Keystroke is F10. If this doesn't work you need to upgrade your BIOS in order to be able to do that. To do so, download this file: ftp://ftp.compaq.com/pub/softpaq/sp10501-11000/sp10870.exe Download the file, create a diskette from it. Then boot from the diskette. Be very careful and make sure that no power loss occurs.
You might turn the notebook into a door-stop otherwise.
2.) Whatever you do, I would suggest to check whether access to BIOS-Setup with F10 on startup still works.
If not, the DIAGS partition where Diagnostics- and Setup-software is store would be missing.
Feb 21, 2010 | Compaq Armada 1580DMT Notebook
Where is the bios located on the dell 1525
It is a chip soldered onto the motherboard. It's not something that is user serviceable. Updating a bios is seldom necessary for 99% of the people. Unless there is a specific problem you don't have to do anything to the bios. You can access CMOS or the bios by entering setup when you boot up your computer. Usually by hitting F2, F10, F11, F12 or Del. This allows you to change certain features in the way your computer runs. Other than changing your boot devices such as making it boot from CDrom or Hard Drive 1st or 2nd there is generally no reason to play around in the bios.
Nov 28, 2009 | Dell Inspiron 1525 Notebook
When i put the disk in nothing happens
It helps to know what operating system you're installing, what kind of computer you're installing it on. You probably are not setup to boot from the CD rom. You need to enter the system bios at the startup. This is usually done by hitting F2, Delete, F12 or other hot key to enter the system bios. You should get a message when your system boots up about which key to hit to enter setup. In the system bios you will find boot options. You need to set it to boot from the CD Rom first and hard drive second.
Nov 06, 2009 | Computers & Internet
SCREEN WENT BLANK THEN WINDOWS COULD NOT START BECAUSE THE FOLLOWING FILE IS MISSING OR CORRUPTWINDOWSSYSTEM32CONFIGSYSTEM\r CAME ON THE SCREEN TRIED TO GET INTO BIOS BUT ONLY COMING UP WITH PLEASE WAIT
Dear user,
if you are trying to access bios for setup of CD ROM as a first boot device and having problem to access the bios then here is an advice for you.
most of notebooks or systems have a special key assigned to select the boot device at startup without entering in bios setup. therefore please hit function keys at startup like F9,F11,F12 when you start system. F9 and F12 keys are most commonly used for boot device selection.
hopefully you will understand my advice.
Please dont forget to RAte my solution
Sep 09, 2009 | Acer Aspire 3000 Notebook
Which key to press at startup to gain access to BIOS E2180 Intel
There are a number of keys used to access the system BIOS at startup. F2 is probably the most common, but I see you've already tried that. I've also seen the ESC and DEL keys used, so try those. If that doesn't work, start working your way across the F1-F12 keys.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 13, 2009 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Bios shutdown
Mike:   Look in your manual to see how to get to the BIOS setup screen. Find the BIOS shadowing or catching and shut it off.    If you need a manual download it. If you cannot get it going again, doing that . Try using the reload CD's. If you don't have one ,again look in the book and see if it is on the hard drive or wher.e If you need additional help, just ask.
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=447346&submit.y=5&submit.x=6〈=en&cc=us
Jan 24, 2009 | HP Compaq nc6120 Notebook
Updated bios problem on a780gm-a
I think you had a bad flash!
So re-download a new bios file from there web site and try again, with these instructions....
Updating the BIOS
You can download and install updated BIOS for this motherboard from the
manufacturer’s Web site. New BIOS provides support for new peripherals, improvements
in performance, or fixes for known bugs. Install new BIOS as follows:
1 If your motherboard has a BIOS protection jumper, change the setting to
allow BIOS flashing.
2 If your motherboard has an item called Firmware Write Protect in Advanced
BIOS features, disable it. (Firmware Write Protect prevents
BIOS from being overwritten.)
3 Create a bootable system disk. (Refer to Windows online help for
information on creating a bootable system disk.)
4 Download the Flash Utility and new BIOS file from the manufacturer’s
Web site. Copy these files to the system diskette you created in Step 3.
5 Turn off your computer and insert the system diskette in your computer’s
diskette drive. (You might need to run the Setup Utility and change the
boot priority items on the Advanced BIOS Features Setup page, to
force your computer to boot from the floppy diskette drive first.)
6 At the A:\ prompt, type the Flash Utility program name and the file name
of the new bios and then press <Enter>. Example: AMINF340.EXE
040706.ROM
7 When the installation is complete, remove the floppy diskette from the
diskette drive and restart your computer. If your motherboard has a
Flash BIOS jumper, reset the jumper to protect the newly installed BIOS
from being overwritten. The computer will restart automatically.
Hope This helps
Have a nice day!
Dec 27, 2008 | EliteGroup ECS A780GM-A Motherboard - AMD...
Diskette drive 0 seek failure
Does the PC have a floppy drive? If it doesn't It appears that your BIOS (Basic PC setup) thinks that there is one! I think that pressing f2 on boot will bring you into the BIOS setup.
In there, see can you locate any reference to 3.5 inch floppy and amend it to the setting which suits the config of your PC.
Please take care as to what other settings you change in the BIOS
If you find this sugestion helps please take time to rate it
Aug 30, 2008 | Computers & Internet
Startup with F12
Welcome to FixYa! Delete is the BIOS setup key at POST. F12 is a one-time boot option. Safe mode is accessed by repeatedly pressing the F8 key at the first Windows splash screen. Post again if you have further questions. Steve
Aug 05, 2008 | HP Compaq nx6125 Notebook
Toshiba Satellite Pro 4600 Notebook Logo
217 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
