Question about Canon Pixma Ix6550 A3 Colour Photo Printer
Ix6550 blink 19 times - Canon Pixma Ix6550 A3 Colour Photo Printer
Sony bravia klv 24ex430 red light blinking 2 times?
KLV-24 EX430
RM-GA022
Troubleshooting
3-3. Standby Led Blinking
3-3-1. 2-times Led blinking
2 times Blinking
Check DC voltage at
JL6023
Is it 18V 19 5V?
Yes Change
- 19.5V? B*board
No
Take out adaptor
and test at adaptor Yes
output is it 18V - 19.5V?
Change
B*board
No
Change
adaptor this is flow chart for 2 blink
Aug 13, 2017 | Sony Televison & Video
How to solve led light orange color in canon pixma ix6550
just change your cartridge with a new one, the printer will work perfectly.
Jun 17, 2015 | Canon Pixma Ix6550 A3 Colour Photo Printer
19" sanya tv-model DP19547 flat screen manual
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 14, 2014 | Televison & Video
B200
A new print head would not be cost effective. For the price of a printhead you could replace your printer.
Jan 21, 2014 | Canon IX6550 A3 Inkjet Printer Inkjet...
It wont turn on power lite just blinks screen stay black
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 26, 2013 | Samsung LN-T1954H 19 in. LCD HDTV
Canon ix6550 not working
Have you tried going into the printers option in your control panel? If not, hopefully the printer will show up there and you can try updating the driver and make sure you use the 'update from the internet' option. If the printer doesn't show up, try adding it by utilizing 'add new device', and select the model from the list. If neither of them work for you, you can try this site, but I fear it's pretty much the same as what you've done: http://www.canon-europe.com/Support/Consumer_Products/products/printers/InkJet/PIXMA_iX_series/PIXMA_iX6550.aspx?faqtcmuri=tcm:13-829771&page=1&type=faq . Good luck! :)
Aug 27, 2012 | Canon Pixma Ix6550 A3 Inkjet Printer
My d52w20b rca tv will not turn on and if you hold down the power buton down the led flashes a code 19
All the ITC222 series will blink 19 if they have a no start situation regardless of the problem, Since the set wont power up the Main eprm cant communicate so it blinks 19 which means it cant identify the chassis. When you press the power to turn it on does the power light come on briefly then go out 3 times? Let me know and I will assist you with the problem. Also do you hear any sounds when the power is pressed?
Nov 27, 2009 | RCA D52W19 52" Rear Projection Television
Sony Wega
Please count light flashing again. Light flash time is "0.3 Sec" and there would be pause (light Off time) for "3 Sec". Start counting after pause to next pause.
May 31, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Power blinks green on lcd 17" veiwsonic
This is a duplicate posting, click on the link below to view the active post: http://www.fixya.com/support/t161845-17_veiwsonic_power_blinking_green
Jul 28, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Canon Pixma Ix6550 A3 Colour Photo Printer Logo
52 people viewed this question
old marine
old marine
