Question about Elna Sewing Machines
Why does fabric get caugh on the roll hem devise when over locking
  • Elna Master
  • 1,133 Answers
This sounds like an overlocker/serger machine you are using? if the fabric is catching on the overlocking tongue it could be a number of factors, have you lifted the top cutting blade out of the way and forgot to put it back into place? That would be my first thought, the top and bottom blade move against each other cutting the fabric. Rolled hemming usually requires the blade to be set on about 2, or middle of its setting range, the stitch finger is pulled back out of the stitching area, top looper thread is loosened off and bottom looper thread is tightened up, resulting in the top looper thread wrapping around the edge of the fabric and pulling the cut edge down under within the seam, forming the rolled hem.
Posted on Feb 15, 2015
  • 19 Answers
SOURCE: How many foot for Baby lock E5280 like flat, blind, rolled hem?
i dont have a baby lock but on my machine i change from rolled hem to flat needle plate
or change setting to n from r also loosen lower looper tension as rolled hem requires a tight lower looper tension.
hope this helps you
mary h
Posted on Jan 05, 2009
SOURCE: rolled hem on chiffon
Turn under the edge just about 1/4" and do a rolled edge then you can go back and trim off any of the folded under fabric that may show. Also, this keeps the hem from pulling away so easily. You may also try putting some water soluble stabilizer under the fabric before you serge.
Posted on Mar 19, 2009
  • 136 Answers
SOURCE: Juki baby lock EA 605 'rolled hem'
No way to rolled hem, machine as much as 40 years old
Posted on Aug 29, 2009
  • 632 Answers
SOURCE: Satin Fabrics keep jamming when trying to hem
Satin is a slippery fabric besides being thin, this is when a walking foot or PFAFF's IDT system help feed both top and bottom sheets. You could also be using a sharp needle vs a ballpoint. Change your presser feet with either a roller or teflon coated.
Posted on Sep 09, 2009
  • 980 Answers
SOURCE: please can you tell me if it is possible to do a
There is a definite art in doing a rolled hem at the best of times and on a delicate fabric you have to be good, there is no way of explaining you need to be shown.
Posted on Nov 01, 2009
Can I make rolled hem with a Juki MO 2366 N?
Most likely. Most overlockers can make a rolled hem. You will probably want to do a lot of practicing on scrap chiffon before trying it on the real thing. It involves using only one needle, both loopers, and making appropriate adjustments to the machine.
Serger 101 Threading the Juki MO 654de Machine for Roll Hemming by CKC...
How to Serge Rolled Hem
Serger Stitches 101 Cheat Sheet Never Ever Without It Your New Must Have...
Bernina has some very nice Serger Workbooks that could be helpful:
Bernina Mastery Workbooks
Nov 13, 2017 | Juki Sewing Machines
Best tension settings for a rolled hem on stretchy fabric
you don't mention if the machine is a sewing machine or serger, or the name or model number?
Apr 15, 2016 | Sewing Machines
How to do a rolled hem on very fine fabric
There should be a special foot for this procedure. I run a straight stitch near the edge first.
Mar 07, 2015 | Elna Sewing Machines
Make a rolled hem
If you want it done entirely by machine you will need a special attachment. You'd have to check the make and model of your machine to find out if there is an attachment available from the maker. If not, there are some companies that make general attachments, and they'll list what machines these will fit. Check online sewing supply houses for this kind of thing.
You can also make one by hand. Any decent sewing book would tell you how. Usually you sew a straight stitch along the hem, using quite small stitches. Trim hem to a quarter inch from the stitch line. Crease the fabric or press it along the stitch line to the inside. Anchor your hand thread, then take a short stitch right along the stitch line. Next catch one thread of the fabric a quarter inch above the stitch line. It's just a basic running stitch, back and forth. Every few stitches, gently snug up the thread, which will roll the hem over. The finer the fabric, the smaller the stitches you take where they'll show should be.
There are some images that will help, if you enter the following search terms in google, you will see several pictures. Type the words," Illustrations for how to make a rolled hem by hand ? " and you will get a load of ideas.
Oct 09, 2014 | Sewing Machines
I am not getting an even rolled hem on a heavier fabric. I am only using 3 cones of Maxi Lock.
You can not do a rolled hem on heavier material. It is only for thin cloth. You have to do a 3 thread narrow edge on heavier cloth.
Aug 02, 2011 | Baby Lock Imagine
I was doing a rolled hem on flannel baby blankets. My machine stopped and overload notice came up. How long before it will work again?
the rolled hem should only be used for light weight fabrics, if you read the manual it will tell you this..flannel is just too thick a fabric.
Jun 08, 2010 | Husqvarna Huskylock Computerized 936
Please can you tell me if it is possible to do a rolled hem on delicate fabric using a Jaguar Epochlock 055D overlocker and if so how
Nov 01, 2009 | Sewing Machines
Aug 26, 2009 | Sewing Machines
hope this helps you
mary h
Jan 05, 2009 | Baby Lock BL1556
Rolled hem on chiffon
Jul 03, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
89 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
