Question about Nokia AC-3X UK Mains AC Adapter Charger
Repair ac 3x charger - Nokia AC-3X UK Mains AC Adapter Charger
Will not charge with either ac charger or car charger
you may have a broken conection on mother board refer to acer for repair information and pricing
Mar 17, 2014 | Acer Iconia Tab A100
Circuit diagram of dell charger for latitude e 6500
Why?
Chargers are so cheap that it is not worthwhile & even unsafe to repair. Just buy a new one.
If you still want to repair, you really do not need a circuit diagram. Just replace swollen (bulging) capacitors and resolder the output cable. Cable is usually broken at the "bending point".
Nov 25, 2013 | DELL Made OriginalGenuineOEM Latitude...
DV7 did not working from fully gharged battery
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, which regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the
AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check.
The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked.
Replacement HP Pavilion DV7 Smart AC Adapter 90Watt 19V 4.74A
Nov 25, 2012 | HP Pavilion dv7-1130us laptop
Aspire 5251-1513 ac adapter broke
Don't do that if you are not good for repairing laptop. That will damage your laptop and be dangerous.
Either repair your laptop adapter or buy a new adapter. If you can't let your laptop charger repaired by yourself, you had better replace a new charger.If you are on a budget on a new charger, consider buying a third party charger:Intocircuit Acer Aspire 5251 AC Adapter 65Watt 19V 3.42A
Sep 30, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
What kind of charger does a Sony Cybershot DSCW80 7.2MP Digital Camera with 3x Optical Zoom and Super Steady Shot need
The DSCW80 Camera is supplied with the BC-CSGB Battery Charger which can be used to charge the battery of the Camera by inserting it to the charger.
You may also use the ACLS5K AC Adapter (not supplied) for charging the battery by using the Multi-connector cable of the Camera.
Thanks for contacting FixYa.
Feb 23, 2011 | Sony Cybershot DSCW80 7.2MP Digital Camera...
I have a LYNX L-3X that I haven't used in over a year and when I tried to use it now it doesn't seem to charge at all. What do I do or try?
If the scooter has been stood for that amount of time without being charged, there's a very good chance that the batteries will need replacing. The charger may not be charging the batteries as most chargers require a minimum voltage to operate (about 16-18 volts) If there is less than that amount of voltage in the batteries, the charger will not 'kick in'. This is the most likely cause, but other problems may exist which I cannot be identified without seeing the scooter (i.e. Fuse blown in charger, plug or charging circuit or fuse blown in battery wiring harness etc).
Jun 25, 2010 | Lynx L-3X Compact Scooter
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Charger not recognized
Folks.
The issue with most of the Dell charger issues rekated to a new charger not being able to charge the battery is the fact that Dell has a screwy proprietary circuit design in their laptops and chargers.
It seems that the Dell laptops are designed so
only Dell chargers will work. While other
brands of chargers will power the laptop when plugged in,
they will not charge the battery.
They do this so they have a monopoly on their chargers and thus can charge a frickin' fortune for their, Dell chargers.
Want them to change this? don't buy Dell products for a while. If enough people ban them, they would change this **** overnight!
Jul 07, 2009 | Dell Inspiron 1501 Notebook
Inquiry
Try to switch it on connected to an AC charger, if it switches on , then it is a battery problem. If not, it may be the AC charger, or oxide in the charger contact.
I sugggest also going to a local phone repair shop, and eventually testing a different battery and a charger.
If the battery works, replace it, if it is not the battery or the AC charger, then ask the fee for repair. Usually it is the charger or the battery.
Oct 14, 2008 | Sony Ericsson P910i Cellular Phone
Pewer problem
Jul 09, 2008 | Sony Ericsson P910i Cellular Phone
Nokia AC-3X UK Mains AC Adapter Charger Logo
21 people viewed this question
Top Nokia Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you a Nokia Luggage and Travel Expert? Answer questions, earn points and help others
