Question about Video Game Consoles & Games
When did Cathrine ofArogon die - Video Game Consoles & Games
What is included in a die set?
A die set is a collection of equipment that can include; upper and lower die shoes, punch and die retainers, guide pins and bushings.
Jan 28, 2013 | Tools & Hardware - Others
I have a makita jn1601 nibbler and I'm trying to change the punch. How do I do this?
Removing or installing the punch and die
Always replace the punch and die as a set.
To remove the punch and die, loosen the lock nut with the wrench.
Remove the die holder from the tool.
Use the hex wrench to loosen the bolts which secure the die. Remove the die
from the die holder.
Use the hex wrench to loosen the screw which secures
the punch.
Pull the punch out of the punch holder.
To install the punch and die, insert the punch into the
punch holder so that the notch in the punch faces toward
the screw.
Tighten the screw to secure the punch.
Install the die on the die holder.
Tighten the bolts to secure the die.
Then install the die holder on the tool so that the punch is
inserted through the hole in the die holder.
Tighten the lock nut to secure the die holder.
After replacing the punch and die, lubricate them with machine oil and run
tool as needed
Here is a link to a manual in case you need it to:
http://www.makita.ca/data/upload/tools/(JN1601)883894-943_75725_owner_English.pdf
Thanks for using FIXYA
Please rate us.
May 25, 2011 | Makita Garden
I want to know where to go to catch the grey hound
im not sure where you are but the grey hound bus station in ottawa is on cathrine street 2 blocks west of bank street
Mar 03, 2011 | Cycling
Schommeling temperatuur bij statoner als ik bij stilstand de moter sneller dus gas geef laat draaien dan zakt de temperatuur weer.
english or spanish please ,sorry no german ,i am assuming that you mean the temperature is rising when stationary ,so the cooling fan isnt working which could be a sensor or a fuse but i would need more details
Aug 02, 2010 | 2008 Chrysler Pt Cruiser
My Pontiac G5 GT makes a clunking noise when turning
sounds like a drive shaft clip worn have it checked out or check the disc brakes might of come loose hope this helps
Aug 24, 2009 | 2008 Pontiac G5
Ipod died
Hi! Try to reset your ipod by pressing menu and center button for 6 seconds. If still doesn't work then there might be a problem with your battery. If your ipod is under warranty then get it replaced else you can go for battery replacement. This link will prove helpful-
http://www.apple.com/support/ipod/service/battery
Dec 27, 2008 | Apple iPod MA446LL/A MP3 Player
Margherita 2000
put belt on motor pulley. start belt onto large pulley. turn large pulley by hand so belt will slip on. does require some strength
Sep 07, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Brother fax machine 8360p
It seems that someone has sent a large fax that has filled the memory. What they may have done is accidentally programmed one of the buttons to send to #342. This is easily done, if those keys are pressed and then an empty program button is pressed right after. You will have to remove the program from the que 1st of all, then remove the program from the button.
Jun 09, 2008 | Brother Office Equipment & Supplies
Video Game Consoles & Games Logo
51 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
