Question about Oregon Scientific Oregon Gator Mulcher 3-N-1 Blade For 50-Inch Cub Cadet Lawn Mowers #90-656
While mowing the blade disengages - Oregon Scientific Oregon Gator Mulcher 3-N-1 Blade For 50-Inch Cub Cadet Lawn Mowers #90-656
Mower will start fine when I engage the blades it will mow for a short time then the mower wants to stall and will if I don't disengage the blades
Are the blades turning freely when disengaged. Is it possible something is interfering and binding them somewhat (for example, if the mower picked up some rope and it wrapped around the shaft to the blades)?
Apr 02, 2016 | Garden
Blades disengage
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 22, 2016 | John Deere Garden
I was mowing with a timecutter 4200 the blades stopped and won't restart what do i do
check fuses and then start testing the wiring and clutch
Sep 12, 2014 | Garden
My mower will die everytime i engage the blades to mow
Check to see if one of your deck spindles isn't seized. Disengage the blades and turn each blade to see if its free. Sounds like either a spindle is seized or your electric clutch on the motor has a problem.
Jul 20, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Disengaging blades when mowing completed
the cam plate that the tensioner pulley is mounted on that rotates back around to tighten the belt as the cable or rod is engaged is likely rusted and worn, there is a bushing in this pivot that can be removed and cleaned fairly easily with a abrasive wheel or pad and lubricated upon reassembly.
Jul 04, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
When I finish mowing yard I disengage mower blades but they keep on turning why
If this mower has a manual lever that has to be pushed up in order to engage the blades then check the tension pulley that connects to the lever cable on the top of the deck,it probably need to be lubricated or cleaned in order to move freely back to the normal position.
May 14, 2010 | Garden
Blades will not disengage
SOUNDS LIKE THE CABEL IS BAD IF IT HAS ONE OR THE ENGAGEMENT IS BENT
Oct 08, 2009 | Craftsman Garden
Oregon Scientific Oregon Gator Mulcher 3-N-1 Blade For 50-Inch Cub Cadet Lawn Mowers #90-656 Logo
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
