Question about Zebra GX430t Thermal Printer
Gx430t red and green light bleanking - Zebra GX430t Thermal Printer
Zebra gx 430t printer when I turn it on the light is blinking green/red
Do a factory reset on the printer.
Check you printer driver settings if you are printing using it.
Jan 14, 2016 | Zebra GX430t Thermal Printer
Zebra GX430t, print two blank label when switch on
this is because printer calibrates every time u power on, this is a default setting, and its good if u using diferent labels all the time. you can change the settings thought driver,and change (when power on - "doing nothing" dont forguet to reboot Thanks Paulo.
Apr 08, 2014 | Zebra GX430t Thermal Printer
Won't work say's clean
the clean light is flashing a error message , remove kick plate and get the tech sheet to see what the error is .
Feb 20, 2013 | Kenmore Dishwashers
I bumped somthing and the green light bleankes it will nor move
Check the fuses. There should be fuses in case there's a short in electrical circuit.
Nov 15, 2012 | Health & Beauty
Model GX430T, new out of box, have installed the older versions. Noticed ribbon might be newer, but can not get it to print, not even the configuration. Checked ribbon, black, its on right. Is there a way...
assuming that is is a printer scanner unit ( models mean nothing with out make and type) you will have to download the drivers for it from the manufacturers web site for that particular machine
Sep 02, 2017 | Zebra GX430t Thermal Printer
How to reset IP address on GX430T label printer
http://www.scanonline.com/pdf/PrintersZebra4/GX420t/ProductDocumentation/980612-001A_GX420tUGen.pdf Here is the manual it will tel you how to go about resetting the Ip address on this printer, If its connect to your RJ45 cable or you have a print server you will need to reset it using other means but this should set you on the path to help here, thanks please do not forget to leave a rating.
Aug 03, 2010 | Zebra GX430t Thermal Printer
No lights
check your fuses
Nov 27, 2008 | 1997 Dodge Caravan
Left orenge light is bleanking
Here is the solution from HP's website:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09170&lc=en&dlc=en&cc=us&product=59129&rule=26188&lang=en
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 26, 2008 | HP DeskJet 940c InkJet Printer
Zebra GX430t Thermal Printer Logo
56 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
