Question about Canon PIXMA iP4300 InkJet Photo Printer
1 Answer canon ip4300 error [5700] - Canon PIXMA iP4300 InkJet Photo Printer
mwalker02
  • 41 Answers
SOURCE: 5700 in mp520
Canon is fairly standard with their error codes no matter the model. Error Code 5700 basically means the paper sensor is not working properly. If this is the case then you will need to buy another printer. Most repair shops will charge more to fix the old one then you would spend on a new one. Sorry for the bad news. Although, I would strongly suggest you contact Canon Tech Support to validate this information. You can reach them at the number below between 8AM and 12 Midnight EST. Good Luck!
Canon Tech Support: 800-828-4040
Posted on Jun 08, 2009
SOURCE: I am getting error code 5700 and cannot print.
error 5c00
Posted on May 18, 2010
SOURCE: canon ip4300 printers
to know what your printer wants to say,
just go to "start menu" then click on "printers and faxes", and "right click" on the certain icon of the model of your printer....then click on "maintenance tab" and click on "printer status"...then you will see the problem of your printer........
Posted on May 27, 2010
  • 37 Answers
SOURCE: canon IP4300 flashes orange and green
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Posted on Aug 02, 2010
  • 123 Answers
SOURCE: 5700 error on my ip4300, how do i fix it?
try reinstalling the printer driver canon pixma ink
Posted on Dec 02, 2011
Error code 311
The Error 311 indicates a communication error between the Mac and the printer. If you upgraded the Mac from Leopard to Snow Leopard, there could be older driver files for the iP4300 that are conflicting with the new driver. Therefore I would start your repair by trashing all of the Canon files.
The first step is to disconnect the USB cable between the printer and the Mac.
The next step is to delete the current printer queue for the iP4300. Open Print & Fax, select the iP4300 in the list and click the minus ( - ) button to remove the queue. You can now exit Print & Fax.
The third step is to remove the Canon files. These are located in HD > Library > Printer > Canon > BJPrinter. Select all the files inside this folder and trash them. Then empty the Trash and restart the Mac.
With the Mac restarted, you can now run the installer for the 10.6 driver you downloaded from the Canon web site. Ensure this driver is version 10.26.0.0.
Once the driver has been installed you can connect the iP4300 USB cable to the Mac again and open Print & Fax. If the install has worked, the printer should automatically appear in the Printers list (note that this can take several seconds). If the printer does not appear, click + to add and select the Default view. The iP4300 should appear in this view. Select it and click Add. You may get a prompt stating the printer is already installed. If so, cancel this install and try printing with the new iP4300 queue.
If the error message still occurs, then I would try another USB cable. They have been known to cause the 311 error.
Nov 09, 2015 | Office Equipment & Supplies
Says there is an error 6A00 am trying to replace magenta cartridge
On this site there is a solution for your problem.
The solution is meant for Canon IP4300, but can be used for Pixma MP830 as well.
http://tricks-collections.com/solution-canon-pixma-ip4300-error-6a00/
Regards
Sep 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Canon Printer iP4300 Error B200 How to fix Error
All my search, b200 error indicates a dead print head.
Jul 17, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
The copy shows a error code 6A00 I can't do anything with it the ink cradle does not light up
Solution Canon Pixma IP4300 Error 6A00, this reset tips is from someone in printer forum but the tutorial in picture. You can follow the instruction in the picture to solve error 6A00 in Canon iP4300. Some users say on the forum this reset method also work on Canon iP4200 and Canon MP800. Look the picture below to view the complete tutorial how to solve Error 6A00
Larger picture here
Jul 07, 2011 | Canon Office Equipment & Supplies
Error 1250 on PIXMA ip4300 printer. Despite open tray messae will not o away or allow printing to start.
the error message means there is something wrong with the printer and if the problem is not attended to, the error message will not go away.
In this case, the error message showing on your canon ip4300 is related to a door problem. It has something to do with the front door of your printer. I think the front door of your printer is closed of which is supposed to be opened.
So, the solution is to Open the paper output tray of your printer and the problem should be solved.
Good luck.
May 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip4300 printers
Mar 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
My ip4300 printer shows - Service Error A600-
goes through this link and try.........
Oct 07, 2009 | Canon Office Equipment & Supplies
5700 in mp520
Jun 08, 2009 | Canon MP520 All-In-One InkJet Photo...
Canon iP4300 service error on my printer
dear
Don't waste money on Printer Ink. Save up to 65% on toner cartridges, ink cartridges and printer supplies. <a href="http://www.concordsupplies.comhttp://www.concordsupplies.com">http://www.concordsupplies.com</a>
May 28, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
37 people viewed this question
old marine
old marine
