Question about JBL Encounter 2.1 Computer Speakers
What power supply do I need for a jbl encounter?
How many input voltage do i need for my jbl creature ii.is it ac or dc?
JBL Creature needs a 18V, 3.5 Amp, AC power supply. JBL original power supply model is TA66180350-B2 made in China. In put power is 220-240V, 50 Hz-0.5 Amps. The AC supply is made to a dual rail supply inside the creature using a diode bridge.
Sep 08, 2014 | JBL CREATURE II Computer Speakers
Need replacement power supply
JBL parts online
ebay seller has this listing
AC Adapter For JBL on stage 400p Speaker Dock iPhone iPod OS400PBLK Power...
the power source specs are on a sticker on the device or online search for its specs
nothing wrong with universal power supplier from an after market power source supplier
Mar 22, 2017 | JBL Audio Players & Recorders
I have the JBL speakers which are really decent but i want them to be as loud as possible! if i plugged in my logitech speakers into one of the inputs that i would normally put one of my little speakers in...
It should be OK BUT if the JBL and the Logitech are plugged into different mains outlets you could get a hum from one or both sets of speakers. This hum is caused by an earth loop when the speakers are connect to different mains outlets.
The fix.
Connect a power board to a mains outlet and then plug the mains connections from both set of speakers and computer to this power board.
Oct 25, 2012 | JBL Encounter 2.1 Computer Speakers
I have JBL encounter speakers and i want use them with my Mac, when i plug nothing comes out (sound)
Wanted to clarify , if the you plug in a headphone are you are able to get the sound from them . If yes than , you might need to check the connection on the speakers. If the headphones are also not working through the audio jack . You would have to check the following
1. Check if there is any external damage to the audio jacks both on the MAC and the JBL connector
2. Check if the sound properties on the MAC are configured correctly
3. Check if the sound card drivers are installed correctly.
Thanks for using fixya
Proton
Mar 13, 2012 | JBL Encounter Speakers Computer Speakers
Have a JBL Encounter 2.1 Multi Media Speaker System need to find a power lead and speaker jack for it im resident in uk and need voltage requirements regards
you shouldnt have to worry about a speaker jack for it. it should work anywhere and a simple usa to uk power adapter will work for you it just changes the plug type and up or downs the voltage (i cant recall if uk is higher or lower then the u.s)
Mar 23, 2011 | JBL Encounter 2.1 Computer Speakers
I have a power problem with my JBL Encounter system. Since I played it very successfully on Saturday night with some marvellous music, it is no longer working. I have check the fuse in the plug and...
Hello
its power supply section has failed. you have to look into it for further trouble. Replacing fuse or line chord won't give you any result. you have to check wit whether the transformer faulure has occured or not. If it is fitted with a mains transformer, it will have a thermal fuse in it imbeded in between its primary and secondary windings placed inside the transformer and can be accessable if it is taken out. It is meant for to block the transformer woring, if it does overheats due to long run at high volume. Check from this and proceed. you must have a sound knoledge in electroncis and have a concept of soldering to do this work. OK.
Mar 22, 2011 | JBL Encounter Speakers Computer Speakers
I am looking for a power cord for JBL on stage II speakers. Part no. 700-0042-001. Model no.TEAD-48-180800U
The following power cords will work with your speakers
You can purchase the power cord from the following site if you are in the UK:
http://www.power-adapters.co.uk/jbl-7000042001-acdc-18v-power-supply-adapter-p-7165.html
You can purchase the power cord from eBay if you are in the US:
http://cgi.ebay.com/AC-Power-Supply-Adapter-Charger-JBL-700-0042-001-/350422898000
Regards,
sjstore2
Dec 18, 2010 | JBL CREATURE II Computer Speakers
Just wondering what the power supply output JBL Media 3 Speakers
I have a pair of Media 3 JBL computer speakers. I am using a generic 12V DC adapter rated at 1000mA with a positive tip polarity, and it works fine.
Aug 15, 2009 | JBL Audio Players & Recorders
Power supply
dear gmonsta
u can buy a 12 volte 1 amp power adaptor....
and normaly on all computer speakers supply requirements are alrady given as instruction....at back side of u r speaker...
for more information on this topic u can mail me too sigma_shiva1@rediff.com
sir
if u r problemis solved then let me know by VOTING me.....
-Was this solution helpful? Show your Appreciation by rating it:AS FIXYA
Nov 12, 2007 | Audio Players & Recorders
JBL Encounter 2.1 Computer Speakers Logo
66 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
