Error code E03 bush washing machine - Washing Machines
4 Suggested Answers
  • 193 Answers
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
beltronic205
  • 1466 Answers
SOURCE: the washing machine does not spin and displays an
Make sure water pumping out if not check /clean filter
Posted on Oct 03, 2009
  • 6277 Answers
SOURCE: my washing machine washes then
You don't say what make/model it is and different machines have different fault codes unfortunately! So I'm going to guess- no promise ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 21, 2011
Hi I have achoover washing machine and its coming up e03 this is the 2nd tine its done this last time i left it a couple of days of and it worked fine what do you think it could be.
This code means the drain pump inlet is plugged (most common) or the pump is defective or the control board is defective that operates the drain pump. Please read the information at the link. Error message E03
Feb 01, 2017 | Washing Machines
Error message E03 coming up on my Bush A146CDB Washing Machine. Any help much appreciated.
fault code 3 usually means:
Not drained in time allowed - washing machine fails to drain water
Check that filter is not blocked or obstructed
Check drain hose is clear of any blockage or obstruction
Those above are checkable by yourself and the ones below need to be checked by a professional.
Check wiring to drain pump
Check drain pump is not defective
Check level sensor or switch
Check wiring to level sensor
All the best
Aug 17, 2016 | Washing Machines
Wa250 3-L Komatsu wheeler loader has a call EO3. What the sequence yo the code out?
Re: error code E03 on washing machine
Eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Oct 01, 2015 | Washing Machines
Canon pixma mp495 error code E03
e03 is paperjam or out of paper error, make sure you have a decent amount of paper in the tray. open up all the doors on the printer and make sure there's nothing stuck inside the machine.
Apr 03, 2012 | Canon Office Equipment & Supplies
Hi,my washing machine keeps showing e03 when i do a wash..it never completes a wash,can you give me some advice?
E03 is a common error for almost all washer manufacturers. What is the make and model number of your machine?
Dec 31, 2010 | Washing Machines
Error code E03 on washing machine
Sep 28, 2009 | Washing Machines
Washing Machines Logo
496 people viewed this question
Top Washing Machines Experts
