Question about Tecnik TKL9290 Front Load Washer / Dryer
The drying process works through but no heat is produced. It was OK yesterday
  • 4 Answers
Two options:
1- Heating element is dead.
2. Thermostat is faulty. this unit is normally located on the inner surface of the drum and can be easily accessed after removing the rear cover. It is normally installed in a rubber housing.
Good luck.
Posted on May 13, 2014
Why does The drying process not produce any heat?
If your dryer is electric: need to check for two things: bad over-temp thermostat (open)...or...open heating elements. If gas, check pilot and/or auto firing circuit.
May 13, 2014 | Tecnik TKL9290 Front Load Washer / Dryer
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
No heat in dryer
Check the wiring first. If that looks ok unplug dryer from wall then remove the heating element and test it for continuity. If it is wide open then it is bad.
Jun 18, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Yesterday i was drying clothes and then all of a sudden it is running but not putting heat out...when it finishes the clothes are not wet not really damp but not dry
Heating element needs to be replace. It made by several sections to produce heat. some section are bad so heating didn't come on with its full capacity.
Apr 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Heat is sporadic. model DDE5900RALWH erial G246248G
Make sure lint filter is clean also frre airflow from Exhaust, if tisis ok could be thermostat or element, try basic stuff 1st...
Feb 22, 2010 | Dryers
We have an Amana distinctions dryer model
you need to replace the thermostats on the element.
Oct 24, 2009 | Dryers
Dryer does not heat up/ dry clothes
sound like heater or stat call them out.
Sep 28, 2009 | LG DLE7177 Dryer
No heat is produced on any cycle
Check the fuse located in the back of the dryer. First unplug the dryer. Then take the back panel off. Now look for a white or tan piece with two wires going to it. It's about 3/8" wide and 1 1/2" long. This is your fuse. If you have no way to test it. You can connect the two wires going to it together, tape them so that they will not tuch anything and short out. Turn the dryer on and see if it heats. If it does, dont leave it like that. It a fuse. A safety devise. Replace it before you dry a load.
Aug 15, 2009 | Whirlpool Washing Machines
Our dryer was working yesterday morning, but later in the day it would continue to run but would not produce any heat to dry the clothes.
If the dryer runs but doesn’t heat, don’t even think it’s the thermal fuse. If the thermal fuse was the problem, the dryer wouldn’t run at all.
First thing to do is verify your source voltage for the dryer; for those of you in Manhattan, this means to use your multi-meter to measure the voltage at the dryer outlet to make sure you have 240v. Y’see, Slick, the dryer motor only needs 120v supplied by one of the lines to run. But the heating elements, on the other hand, need 240v supplied by both lines to get hot.
If the source voltage is ok, then the most likely bad parts are listed below. As always, you should use your meter and the tech sheet supplied with your dryer (and cleverly hidden inside the control panel) to verify:
1. Even Heat Board
2. Heater Relay
3. Thermostat
4. Sensor
May 03, 2009 | Whirlpool ET8CHEXSQ Dryer
Washing Machines Logo
41 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
