Question about Toshiba Satellite M35X-S161 Notebook
Blank display machine displeys intermintent have changed memory no change.what might the problem
  • Patrick Kam May 11, 2010
    Memory modules may be lose. Did you experience sudden reboots or power off?
  • Toshiba Master
  • 32,281 Answers
You could have a defective LCD screen, If the laptop appears to be booting up and running and the hard disk is spinning and the hard disk LED light is flashing but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jun 24, 2009
My display is blank. Computer power up but dnt show nothing on screen. Brought it to the shop and i was asked to order a ribbon that connects the laptop monitor to the board. How and where can i get t
The original memory worked fine, when it was changed you lost the display. Have your cousin put the original back, because bad ram will cause the same problem.
Mar 05, 2012 | Computers & Internet
I have a problem with my computer emachines j4501 desktop pc windows vista home premium..after the windows logo the monitor turn blank...but the cpu is still on.... what will i do...
If you can see the windows logo screen both your computer and monitor is working, possible problem could be that the display settings are set to high that your monitor is unable to handle it. Restart computer and keep tapping F8 key. This will take you to the advanced options menu In the list of options here choose enable low resolution mode and hit enter (you can only use your keyboard to choose - use the up / down arrow key) once you enter windows low res mode change it to 800 X 600 and restart the computer Once you are in the right mode now change the display settings accordingly.
Mar 12, 2011 | E-Machines eMachines Desktop PC
Can't change my ym display image
Did you delete it from yahoo profile in program file? But that is not suppose to happen. Well click on displey image option on yahoo messy...click on browse and when the window for image will be appearing with list of image delete all the image (Delete Picture) showing there ....now click on browse and go to that folder where you kept the image you want to add as your displey image....and proceed...I think it will work fine....If that is also not works....check that you shared your displey image....Good Luck
Oct 16, 2009 | Yahoo Messenger
The display wont change even when i close the phone...
the strip is not connencted completely with the jack check and insert strip again..
Plz dont forget to rate
Sep 08, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Dell inspiron 1501 display almost blank
Try changing the memory stick, if still doesnt work, it means the invertor of the screen is gone.
Feb 16, 2009 | Dell Inspiron 1501 Notebook
N70 problem
first u should must be open disply strip and till then clean displey sarounds and check any spungh thare if u don't have any dust untill clean and fix display after chek it u have possitive result antill yhen change disply connector
Jul 14, 2008 | Nokia N70 Cellular Phone
No display .....
Problem :
The control panel will go blank
Solution :
There are many items which can cause the machine to have a blank control panel or no display. There could be a problem with the memory, a blown fuse on the fuse pcb, a defective control panel, boot rom, memory, etc...
One other cause of the problem which was confirmed to cause a blank display condition is the main controller fan. When the main controller fan was unplugged the display would come up and the machine would then give an E code.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Jun 27, 2008 | Canon Office Equipment & Supplies
No receiver display...no audio out
cheak displeys wires pluged in tight does sterio get hot then u see it go off
Jan 23, 2008 | Kenwood VR-2090 Receiver
Toshiba Satellite M35X-S161 Notebook Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
