Question about Home
Aqualisa shower leaking behind tiles, without seeing this a plumber told me it is the cartridge. Is this correct if I replace it will this stop leak
    Problem Solver:
  • 11 Answers
Yes. Remove the handle and look behind the plate, you will see a brass housing (valve) and a plastic insert inside it (cartridge). It is most likely leaking from that due to a bad seal. DO NOT try to replace the cartridge without shutting off the water or 'you're gonna have a bad time'.
Posted on May 15, 2014
Seem to have water leaking under shower into storage competition ment, tried caulking only happens when shower is on and someone is in it very frustrating
Very often happens for a number of reasons
Bad caulking around the shower base and the base drops with the weight of the occupant allowing water past the caulking.
Crack and bad seal on a wall tile.
A split in the base itself which opens up with weight and you can't see with the base empty.
A leak in the pipes behind the wall from the mixer unit to the shower head.
Split pipes or fitting to the drain.
Best way is a full tear down, refurbishment and start anew :>)
Jul 10, 2016 | Home
How to stop water getting inside a single leaver shower faucet?
quite possibly there is a broken O ring inside the faucet .
Jul 17, 2015 | Home
How do I stop shower taps from leaking
remove fawcet handle take out the cartride and replace the rubber oring and bevelled or flat rubber washer on end make sure to shut off water supply first if cartridge is in bad shape buy a new replacement one at hardware or plumbing store reinstall
Dec 12, 2012 | Sterling Plumbing Home
Our jacuzzi tub is 20 hrs old and possibly is leaking. About 6 mths ago we remodeled bathroom &replaced all tile around tub & shower. We do not want to tear out tile. What would be best way to pin...
if you have a water stain on the ceiling below your tub then you have a water leak. There is no easy solution for this. You must get to the underside of the tub in order to watch the jets when the tub is full of water to isolate the leak and then have it repaired by a plumber.
Aug 15, 2011 | Jacuzzi Home
Had a leaky Moen Posi-Temp shower faucet. Installed an Ace Hardware replacement cartridge. Fixed the leak, but now have a water hammer noise in the vicinity of the shower. Is this a common problem with...
I'm not aware of any problems with non moen replacement parts being the cause for a water hammer problem. Start with the simplest and cheapest correction which is using a moen replacement cartridge. If the water hammer persists then you may have to install a water hammer arrester in the plumbing system. This is basically a shock absorber in the plumbing system to stop the effect of water hammer. An arrester will cost you around $10 to $15 at your local plumbing supply shop. If you are not comfortable soldering copper then you will want to hire a licensed plumber to complete the work for you.
I had the same type of problem with an older toilet in my house. It developed a water hammer when it shut off after filling the tank. I replaced the fill valve with a generic universal replacement for about $10 and it stopped. Again sometimes the simplest fix will work. Let me know how it works out.
Jul 19, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Leaking
Make sure you fitted the rubber O ring on the end of the shower flexible hose. That will seal the water pipe.
Mar 29, 2017 | Kohler K-9511-BN MasterShower Shower Arm &...
Kohler shower diverter leaks (behind the wall)
if you have a closet behind the shower or a wall you may be able to get to the diverter without damage to the tile ,are you sure you can't just change the cartridge? most times this is all that is needed to fix a problem like yours.
Jul 22, 2009 | Plumbing
My shower head leaks
for some reason the cartridge set up does a sporadic drip which is infuriating but replacing the insert will not fix it
after the cartridge there is just an empty hose to the shower head and no pressure
Nov 13, 2017 | Price Pfister R897EBK Brushed Nickel...
Shower leak
this may not be a grout problem . I want you to run the shower and check the shower arm behind the wall plate and the toe tester(spout ) for water leaking behind the wall.If you dont find a leak than their could be a problem with the rubber membrane under your tiles.
Feb 01, 2009 | Home
Home Logo
163 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
