Question about Aiwa Audio Players & Recorders
Whay does my AIWA CA-DW63OU start playing by itself?
Was working fine until today - May 11, 2014...Then began to turn on by itself. Have had it for at least 10 years. Tried Power Resets, Reset to default (POWER + SQUARE button), reprogramming the clock, making sure no TIMER is programmed...Still turns itelf ON. Only way to shut it up is by removing the power cord, and re-inserting it when I want to play CD's...
We plugged the unit in to the wall. The clock is flashing and the timer clock showed up again. What to do next to take it off?
Posted on Dec 28, 2015
    Genius:
  • Aiwa Master
  • 1,054 Answers
Are you sure it's not going into demo mode after you turn it off? Is there just lights and display flashing? - that is demo mode. Probably a button on the remote to turn it off.
Posted on May 13, 2014
Testimonial: "Checked per your recommendations - all is per normal - no DEMO mode. The AIWA still comes on by itself. Problem began to happen some 10+ years after having been perfect. You can see by the list of reported problems of this nature, herein, that the problem is well known and that there is no solution to it, since AIWA is no longer in existence (purchased by SONY years ago) and product is discontinued. What I will have to do is, insert an ON-OFF switch in-line with the Power plug, and shut the AIWA and turn it - by way of that ON-OFF switch, as the Stereo works perfect in every other aspect!"
Why does my AIWA CA-DW63OU turn itself ON by itself?
Could be a dirty power switch, or static electricity. Does it have an infrared remote? Maybe something in the room is triggering it. If so, try blocking the sensor.
Dec 22, 2017 | Aiwa Audio Players & Recorders
Aiwa turntable px-e860: Hi, I've inherited this timetable from a friend and it's worked fine until recently but now here's the problem: if I push start, the arm lifts up, moves to the record...
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Oct 10, 2011 | Aiwa PX-E860 Turntable
My AIWA turntable (1989 but still in excellent
Please try and lift the turn table off the casing itself (wheel only) and check if it is belt driven, or by gears. If it is belt driven, the belt might be worn or streched, and needs to be replaced
Jun 07, 2010 | Aiwa NSX-AJ20 CD Shelf System
Hi! I have a problem for reading CDs with an aiwa hifi system
the spindle motor goes bad a lot on these aiwa cd unit
May 12, 2010 | Aiwa NSX-DS55 CD Shelf System
Will not turn on
With the power cord getting hot it sounds like there is something up with the power supply section. Perhaps a faulty transformer or something.
Sep 18, 2009 | Aiwa PX-E860 Turntable
Tape deck problems Aiwa CA-NSX777
Tape drive mechanism requires service (cleaning and lubrication) and might need replacement of drive belts. Of course its qualified tech job.
Jul 25, 2009 | Aiwa NSX-A777 Shelf System
Remove speakers from Aiwa CA-DW630 boombox
They may be heldin by the handle, or tabs that you either need to push or pull on the sides or bottom of the unit.;
Jun 23, 2009 | Aiwa CA-DW530 Cassette/CD Boombox
Subwoofer Shutdown
Whay don't you take a look at your data cable and jack contacts to see if any of them are bent or misplaced. Terry
Oct 02, 2007 | JVC TH-C50 System
Tape decks playig too fast
Hi I can probably tell you what is wrong, but there is usually not much you can do except take it to a shop and have the motor replaced. I most cases there is a hole in the back of the cassette capstan drive motor, or on a small circuit board close to the motor where the speed is adjusted at the factory. You could possibly adjust the speed by ear until it sounded right playing a factory recorded tape with a song you know well, but I recommend these adjustments be left to a tech with a frequency counter. Also, these adjustments normally never need to be touched unless replacing a motor, so it is likely something internal has gone wrong with the motor, and it should be replaced under most circumstances. Hope this helps, Good Luck.
Sep 27, 2007 | Aiwa CA-DW50 Cassette/CD Boombox
240 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
