Question about GPS
Hi all im using Canon SX260 HS which have gps and altitude feature. Im having problem where the altitude reading is not accurate. Any idea why is this happening or anything i can do to make it right. Using it for aerial photography task so the data's altitude is important. Thank you.
    Top Expert:
  • 6,702 Answers
I think this has to do with the limitations of the GPS device build in your Canon. The device is not build to fly in a plane. You are moving to fast. I'm convinced if you are on a mountain the device will have no problem displaying the correct altitude. And when in a plane, the small antenna inside will have trouble finding good signals. Look what the Canon does, while you are still on the ground. See if it finds enough satellites in a short time. Check if the airplanes body works as a shield.
Posted on May 13, 2014
  • Mohd Mirza May 14, 2014
    Thanks Harrie. But I noticed it is not the problem of the airplane. I've tried the camera at a 4-storey building which has a hallway for me to get a perfect signal of gps. The result is still the same.Sometimes the altitude reading can get up to "-" value. I even let it on a tripod on a football field, but still the altitude reading showed 40m.
SOURCE: magellan maestro 4000, 4040, 4050 vs mio c220,c230,
Don't buy a Magellan. There is little to no support, and their web based support redirects to no where useful for upgrades. I'd sell you my 4040, but can't in good conscience sell it to anyone.
Posted on Nov 20, 2007
montecarlo
  • 50 Answers
SOURCE: Keeps seeking but no GPS positioning
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Posted on Jan 10, 2008
  • 5 Answers
SOURCE: navsgo go730 7" inch gps is not reading my memory cards anymore
yes,
first do a backup of ure maps, then format the card , try all the possibilities , fat , fat32 , one of the must work , then after formating , put the maps back on the card , and the gps will read the card
Posted on Dec 03, 2008
hydetech
  • 113 Answers
SOURCE: Garmin Hand held GPS Operation
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It’s hard to cover all the details in a forum like this but I’ll give you a quick primer. I can send you a powerpoint presentation that explains it in a little more detail. To really learn how to read latitude and longitude you should pick up a copy of “Chapman’s Piloting and Seamanship.”
The earth is divided into parallels of latitude and meridians of longitude, also known as lines of position.
Latitude is measured north and south of the equator, with the equator represented as 0 degrees, and the poles being represented as 90 degrees North or South. Latitude lines are paralel to the equator. For example, if I was at the equator I would be at 0 degrees. If I traveled exactly 60 nautical miles to the north, I would be at 1 degree North, and if I traveled another 60 miles I would be at 2 degrees north. Your GPS display will preface the Latitude measurement with an “N” for positions North of the equator and an “S” for positions south of the equator.
Longitude measures your position east or west from the Prime Meridian, which is a line represented as 0 degrees that bisects the earth from north to south and passes through Greenwich England. Halfway around the earth at the International Dateline Longitude is 180 degrees. Measuring Longitude is a little more complicated because the lines are not parallel and requires an accurate clock (your GPS) to compare time at your location relative to the time in Greenwich England. Your GPS display will preface the Longitude measurement with a “W” for positions west of Greenwich and an “E” for positions east of Greenwich.
To make more accurate measurements each degree is divided into 60 minutes. Because the lines are parallel, 1 minute of latitude is equal to 1 nautical mile. Each minute can be further divided into 60 seconds. Each second is roughly equivalent to a distance of 100’ Instead of seconds, the default setting on your Garmin breaks the minute down into tenths, hundredths, and thousandths for meven more precise measurements. Because they are not parallel, lines of Longitude are measured the same way, but the distances vary depending on how far north or south of the equator.
To find out where you are with a GPS, you need a map that shows lines of latitude and longitude on it. The lines will be labeled on the map or along the borders of the map. Most nautical charts show the latitude measurements along the right the left border of the map. Longitude measuremnts will be shown along the top and bottom edges.
Posted on Dec 16, 2008
SOURCE: gps will not announce street names, highway's, etc. Important note: it had been announcing this data since I bought the GPS in December but just recently stopped doing so.
You have to change the voice to a computer voice. Go to where you choose voices on the main menu Change preferences > Voice preferences > Change voice. Find a voice with the word "computer" in the name and select it. At that point you will be asked what you want to be announced. By the way, this is called "text to speech" in TomTom talk.
Posted on May 21, 2009
My flash pops up, but no flashes -- what do I need to fix it. Battery is fully charged!
Is this indoors or outdoors ? If outdoors, ambient light may mean that the flash is not needed. Is there anything to cover this in the manual ?
Jan 14, 2016 | Canon PowerShot SX260 HS Black 12.1MP 20x...
Hi there im having a tomtom 1505tm and my screan goes black but you can hear in background telling you the road,sometimes i can it opens sometimes no pls some help
Check the power saving features. You may have configured the GPS to turn off the screen display while GPS is reading directions.
Mar 04, 2014 | Tomtom VIA 1505TM GPS Receiver
Canon camera shows communicatons error message
Hi, it could be the cable too, but probably a camera driver on your laptop is not loaded or not loaded right way. It could be just part of the driver disabled to start e.g. by some PC optimizing SW. I would recommend to reinstall (uninstall and install again) Canon driver or install again with repair option selected.
If you need to get your photos quickly, try to connect the memory card from the camera directly to your PC (by a memory card reader). You should be able to open it by Canon utility ZoomBrowserEX.
Jiri
Nov 02, 2017 | Canon Powershot Sx260 Hs 12.1 Mp Digital...
Canera does play videos sound
Try playing the video on a computer some cameras don't have a speaker for playback. Try to download it to the computer to see if you got sound. Most camera hook up to a tv using a av cable which you can do as well. Hope this helps
May 28, 2013 | Cameras
Hi. Im writing this because when my" distance till empty" feature reaches 30 it just goes blank. So im wondering how many miles I truly have left and why it never reaches 0?
normally that occurs because the gas in the tank is too low ans sloshing around and the sensor is not able to give an accurate estimate of distance to empty, remember those are just rough estimates ans should never gallons leftbe relied on to be accurate to the last few miles by the time it says 20 miles you probably have 1 to 1-1/2 gallons of gas left
Aug 31, 2011 | Hyundai Santa Fe Cars & Trucks
I can do the same ride with the unit on different bikes and get a variation in total ascent by as much as 200 feet
When starting your device, it acquires sttaelites progressively, then the altitude accuracy is not good at the beginning, so starting altitude and final altitude are not identical if you ride a loop.
Other possible cause is that the cumulation of small errors makes cumulative altitude to vary.
Garmin connect offers a feature that corrects the altitude by smoothing the waypoints, and also by using topology points.
Go to http://connect.garmin.com/
Then upload your data from your garmin device to the garmin connect database, and use the feature named "altitude correction" bottom left of the screen where your ride is detailed
Aug 27, 2010 | Garmin Edge 305 GPS Receiver
Ipod Touch Map Loacation(WPS) Not Accurate!
It is using commonly known Wifi access points from a database. Chances are you have wifi access point names near you that are close to what it knows in Michigan, but it doesn't know them in SC. This is why I want a real GPS in the touch. :-)
Apr 29, 2009 | Apple iPod touch
Adjusting meteo function
Yes, Sir. But remember when pilots reset their altimeter with the local altitude, the pressure value matches the moment wheather pressure. It will be wrong anyway, if you reset you altitude, but the pressure readings are still wrong. Im my case it is happening. The altutide is correct but the pressure of the watch does not match the local pressure. It is 20 hpa over it. By the way, I am an airline pilot.
Mar 05, 2008 | Tissot T-Touch T33759851
Incorrect altitude changes
Here is the link to the user manual for this watch if you need it; http://www.lacrossetechnology.com/k2100/manual.pdf page 12 gives you all the contact details for lacrosse. I couldnt find the info online to be sure, but some of these watches do have a separate pressure sensor for altitude and barometric pressure, and sometimes the path to one could get blocked or it could become faulty. I would contact la crosse and find a dealer to get the watch serviced, you could probably do it yourself but you need to get replacement seals from them anyway (these are important). ask them to check if the sensor is clogged, it happens sometimes. Hope this helps :)
Jun 18, 2006 | La Crosse K2-100 Wrist Watch
GPS Logo
55 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
