Scanner in use
I cannot scan with my caanon all in one printer. It says ''the scanner is not available whie in use by another application or user''. Needless to say it is not in use. I have tunred it on and off several times.
Thanks for any help.
  • 184 Answers
Close all the programs that are running and restart your computer. also turn off the scanner and disconnect it from the PC and power. plug it back after 5mins, reboot your computer, start the scanner program and reconnect the scanner. try to scan again. if it fails, disconnect the scanner and unistall the driver, there might be a conflict somewere. reboot your computer and reinstall the software then connect the scanner and try to scan again.
Posted on Jun 23, 2009
    New Friend:
  • 70 Answers
Close your scanner program.
Start Windows Task Manager > End Process of MP Navigator
This should fix your problem.
Posted on Feb 22, 2011
  • Ralph Faught Feb 22, 2011
    Close the scanner program.
    Start Windows Task Manager (Ctl-Alt-Del)
    Under Processes option highlight
    MPNScan.exe (MP Navigator)
    Press End Process button.
    You should be able to start your scan program again without any problem.
    Close Windows Task Manager.
X544dn scanning and Windows Server 203
Scanning documents at the printer
1 Load the document into the scanner.
Note: Documents may be loaded into the scanner in multiple ways. For information on the different methods of loading documents into the scanner, see the User's Guide that came with the printer.
2 Touch Scan to Network. If prompted, enter the user name and password used to access the printer. Contact your system support person for login information.
3 Select the destination where you want to receive the scanned document. If prompted, enter the user name and password required to access the destination. Contact your system support person for login information.
4 Some additional job options may be available depending on how the application has been configured. Follow the instructions on the screen to update the options. Contact your system support person for more information on each option.
5 Touch Scan It. Depending on how the application has been configured, you may have the option to preview and make adjustments to scanned pages.
6 To scan additional documents, load the next document into the scanner and select one of the following from the confirmation screen:
• Touch Yes, to same destination to scan the document to the previous destination.
• Touch Yes, to a different destination to scan the document to a different destination.
• Touch No to finish the operation and return to the printer Home screen.
Jul 23, 2012 | Lexmark X544dn All-In-One Laser Printer
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
Once a doc is scanned on a 8300 series all in one, how do I get the scanned image from the printer to a word doc? Looked
You can actually scan directly to an application(ex. MS Word application). Also, make sure the Lexmark OCR scan software is installed on your computer (the software is available on the install disc that came with your printer).
1. Load an original document into the ADF or on the scanner glass. 2. Press Scan Mode. 3. Press ? or ? repeatedly until the MS Word application is highlighted. 4. Press check button. 5. Press Start Color or Start Black to start scanning.
Source: Lexmark 8300 Series User's Guide page 72.
May 14, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
I get the message "scanner not available while in
In the software or function selections there should be a reset to factory settings. That worked for my scanner. Also, if that does not work try callig the manufactorer for technical help.
Feb 17, 2011 | Canon PIXMA MX310 All-In-One Printer
Does the Epson tx100 actualkly have a scan function? I cannot find a button or way of working it.
Hello how are you.
Yes it have scanner on your printer but to use you need to do from your pc and go to users options and there you can see to use.
Hope this good for you thank you.
Usai
Mar 10, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Sf 5100p scanner not work in color scan in windows xp
Perhapas because it's a black and whie scanner?
Dec 06, 2009 | Samsung SF 5100 Laser Printer
How do I get this thing to scan?
The user manual is available for download from
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=390315&lang=en&
If you are having problems and have followed the instructions in the user manual, let me know and we can further troubleshoot.
You must have an application that will interface with the scanner, if you do not have one loaded.
Jul 19, 2009 | HP PSC 1610 All-In-One InkJet Printer
I cannot use the printer for scanning
Jul 13, 2009 | HP PSC 1610 All-In-One InkJet Printer
Scangear Error
i think this problem come with windows xp update!
when u started to see this messege?
Nov 30, 2008 | Canon MP610 Photo All-In-One Printer
870 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
