Question about Motorola AP 6521 Access Point
Setting ip address motorola ap6521 - Motorola AP 6521 Access Point
  • Official Brand Answer
  • 3,100 Answers
Contact Motorola Solutions.
Get Support
Mark Motorola Mobility Support
Posted on Jan 05, 2015
What are the connection setting for mms on the Motorola q9m, what is the port and IP address and what gateway shall i choose when setting up the connections to receive and send picture message. thanks
Mms manual settings Please see my previous response.
Jason-
What service provider are you trying to use the phone with?
If Verizon, this should be by default in the phone's settings. Ensure it is enabled on your plan.
Your Service Provider may be able to push the settings through the network. I don't believe there is an option for MMSC settings on the CDMA phones.
Mark
Motorola Support
Oct 01, 2014 | Motorola Mobility Q9m Smartphone
Interface ge1 always down
Get Support
Mark
Apr 12, 2014 | Motorola AP 6521 Access Point
Got Motorola SB5101u cable modem get ip address and works with xp/pro, but can't get vista computer to get IP address even though have configured for automatic ip / dns. Tried everything I could think of
Obviously make sure its set to automatic IP/dns. If thats not working you need to do this
Click on Start -> All Programs -> Accessories -> Right click on command prompt and hit run as administrator.
In Dos prompts type these commands in EXACTLY AS WRITTEN.
netsh i i r r
netsh firewall reset
netsh winsock reset
Also, if you have anti virus like norton or trend micro or mcafee or webroot, you *NEED* to disable their firewalls and possible the entire program.
Some isp's for some reason make it impossible for Vista machines to pull ip addresses dynamically because of a flaw in windows vista. If this continues, i would contact your ISP and request a motorola surfboard 900 series modem, or a cable modem that is in route mode (NOT bridged, as bridged modems will pull a public ip address)
Jan 12, 2011 | Arris SURFboard SB5101 Cable Modem
Motorola SBG900 Assign network address to computer
I guess your modem router was already configured well since it worked already previously. It seems that your motorola router is set to broadcast dynamic IPs (DHCP enabled) and your last connected Pc and laptop were configured with static IP. Please check your "network connection" setting and make sure it is set to "Obtain IP automatically"
Reagrds!
Jun 30, 2009 | Arris SURFboard SBG900 Wireless Router...
How do I set a new address in the 850 motorola router
First, you ned to login into your router (check the manuals for this, Netgear has this printed behind the router near Serial no. etc).
Enable DHCP settings, allocate IP-address range say 192.168.0.1 to 192.168.0.5 (enough for 5 computers connecting via this router). Next, configure each computer to accept new IP-address from router by enabling DHCP.
The settings on a Windows XP Professional Desktop:
Need administrator access to your desktop, right-click on Network icon, Internet Protocol TCP/IP Properties, click on Properties button, then select Advanced properties, you can set DHCP from here.
Dec 17, 2008 | Arris Wireless G Broadband Router (wr850g)
I have just purchased a dlink dir 635 router and am trying to set it up on my Bigpond cable broadband internet. previously I had only a Motorola SBG900 gateway between cable and pc. I now have the new...
The motorola sbg900 is acting as a router itself. I'm assuming this is what you've got? http://promo.bigpond.com/homenetwork/html_new.php
So first, go into your d-link router settings and make sure the THIRD number in the IP address is the same as your modem's ip address. This third number is the "subnet", and it must be teh same for both router and modem.
e.g. if your motorola users ip 192.168.2.1, make sure your d-link is set to 192.168.2.2. Make sure the fourth number is different, but the 1st 2nd and 3rd numbers are the same.
You can figure out what your motorola's ip is by connecting it to your computer, make sure your interent is working, and then run "ipconfig" from a command prompt window. Look for the "Default Gateway" IP. That's your motorola's ip address.
Once the IP addresses match, go into your router's settings and disable the "DHCP server".
Next, plug a network cable to go from one of the LAN ports on your motorola to one of the LAN ports on your d-link. Note that it is LAN port to LAN port. The "internet/wan" port on the d-link is never used for anything.
At this point your d-link will be operating like a "Switch", it knows it is just an extension of your existing network and it won't collide and cause you problems like it was before.
Dec 06, 2008 | Computers & Internet
Wireless router won't connect to my laptop
1. check your network adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
Hope this will help
Nov 24, 2008 | Arris WR850G Router (DHWR850G)
How did i change the ip
Your internet service provider only able to change your external ip address. The only way to change it own by using proxy sites or ip hide software's. Online proxy sites are simple and free of cost . But they worked for some periods only. So you can always check your ip is hide or not at Ip-Details.com
some free online proxy sites
hidemyass.com
hidemyip.com
boomtunnel.org
anonymous.org
Jul 15, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Motorola A1200 MMS Problems
Internet Setting T-Mobile
T-MobileWeb Settings:
Primary IP Address: 216.155.165.050
Secondary IP Address: (Blank)
Access Point Name (APN): wap.voicestream.com
Data Bearer: GPRS
Profile Name: GPRS
Username: (Blank)
Password: (Blank)
Home Page: http://wap.myvoicestream.com
Picture Messaging Settings:
Multi-Media Service Center (MMSC) Address: http://216.155.174.84/servlets/MMS
Validity Period: 72 hours
Hide ID option (if option exists): set to off, no, or disabled
Nov 16, 2007 | Motorola Mobility MING A1200
Motorola AP 6521 Access Point Logo
316 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
