Question about IDEAL 61-958 SureTest Open/Closed Circuit Tracer
Where can I get a manuel for an Ideal SureTest
Where can I get an operating manuel for an Ideal SureTest Open/Closed Circuit Tracer 61-958
    President:
  • 1,723 Answers
Here ya go...
http://www.idealindustries.com/products/test_measurement/circuit_analyzers/suretest_circuit_tracers.jsp
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 27, 2009
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Operator presence lever not workiing
when you get up of the seat you open a circuit, same type deal if you can't go in reverse while the blades are turning
Jun 20, 2012 | Garden
I HAVE A GB WIRE TRACER GET4110R AND GET-4110T. WOULD LIKE INSTRUCTION MANUEL.
The instructon for the GB Instruments Wire Tracker GET-4110 can be obtain from this webpage.
Clink on link:
http://www.smarthome.com/manuals/90502.pdf
Jun 25, 2011 | Gardner Bender Wire Tracker Circuit...
2001 silverado po300 code and po135 code changed 2 o2 sensors still coming up have not changed driver side o2s yet
Well the P0300 code has nothing to do with your O2 sensors just a heads up.
P0300: Random/Multiple Cylinder Misfire Detected
When a misfire occurs, engine speed will fluctuate. If the engine speed fluctuates enough to cause the crankshaft position (CKP) sensor (POS) signal to vary, Powertrain Control Module (PCM) or Electronic Control Module (ECM) can determine that a misfire is occurring.
Causes:
- Improper spark plug
- Insufficient compression
- Incorrect fuel pressure
- The injector circuit is open or shorted
- Fuel injectors may be faulty
- Intake air leak
- The ignition signal circuit is open or shorted
Solutions:
- Perform Injector Service
- Replace Spark Plugs
- Replace Injectors
- Replace Ignition Coils
P0135: O2 Sensor Heated Circuit Malfunction Bank 1 Sensor 1
The front heated oxygen sensor (or sensor 1) is placed into the exhaust manifold. It detects the amount of oxygen in the exhaust gas compared to the outside air. The heated oxygen sensor 1 has a closed-end tube made of ceramic zirconia. The zirconia generates voltage from approximately 1V in richer conditions to 0V in leaner conditions. The heated oxygen sensor 1 signal is sent to the ECM. The ECM adjusts the injection pulse duration to achieve the ideal air-fuel ratio. The ideal air-fuel ratio occurs near the radical change from 1V to 0V.
Causes:
- Harness or connectors (The sensor circuit is open or shorted)
- Front Heated oxygen sensor (Bank 1) may be faulty
Solutions:
Replacing the O2 Sensor 1 usually takes care of the problem
Jan 27, 2011 | 2001 Chevrolet Silverado 1500
How do i test an electic thermo fan in a car. I have tried making a jumper lead from the battery to the positive lead with no effect
The usual operation of this type of fan, is to ground the circuit via the operating relay....meaning that power is fed to the fan and it will need the negative connection made....
  • The thermo switch (which is the sensor fitted into the coolant galleries) is a bi metal, 'make and break' switch....As it heats it will open the circuit....This will cause a loss of power to the coil side of the 'normally open' relay, which without power will fall closed....As the switching part of the relay closes, it will complete the negative grounding and the fan should begin working.
  • To carry out an in car test, pull apart the connector on the fan housing leading to the fan motor.....The black cable with white tracer is negative....the other positive....
  • Use two cables, one positive and one negative and connect to the correct battery terminals....If the fan is okay, it should work....
Regard Johngee10
Nov 19, 2010 | Subaru Outback Cars & Trucks
Joecoolvette, The circuit breaker I was talking about is not the old fuse type. The power outage problem has affected light and receptacl circuits entirely in my bathroom as well as partialy in my...
I would first remove all of the loads from the circuit including taking out the bulbs
Switch everything off and reset the breaker, if it pops then there is a dead short on the wiring due to scrape type flash connection.
It is also feasible that the breaker has gone faulty because they too have a life cycle which shortens every time they are reset
On your breaker board do you have the facility to swop over the same breaker from another circuit.
Regarding tool I assume that you are buying an insulation tester such as a Robin or a Megger?.
In the mean time If you are a competant person I would suggest that you remove the Hot wires from each of the fittings tape them off and mark up where they go back and then reset the breaker, if the problem persists then it is either neutral to earth or a damaged cable
Isolation and testing is the only way forward
Jan 15, 2010 | IDEAL New Ideal SureTest Open/Closed...
WANT TO BYPASS THE LID SWITCH, HOW DO i DO THAT?
There are two kinds of lid switch. One operates when closed, and one when circuit is open.
You need use a multimeter to find out if the switch is open when on (with no electricity on wire when the lid is closed), or closed when on (you get electricity when lid is closed).
If circuit is open when on, then break the contact cutting the wire. If switch is closed when on, then jump the two wires together.
Do not operate the machine for a full cycle with lid switch on, be sure that you know what you are doing and follow all safety rules.
May 16, 2009 | GE Washing Machines
Hello i have Problems with IDEAL Ideal 61-958 Sure Test Open/Closed Circuit Tracer I tray to found the correct MCB for lighting circuit but the tester would not transfer the signal to receiver and the...
Check the batteries in the unit and test it somewhere else, somewhere you know where the circuit box is. Get familiar with the unit. The lights you are testing may go to a box other than the one you think.
May 03, 2009 | IDEAL 61-958 SureTest Open/Closed Circuit...
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Missing manuel Code showing - F 2 -
hi,
F2
Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked - If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
F2
Note: Also see fan thermal switches - Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem.
· Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
Oct 31, 2007 | GE Profile JT912 Electric Single Oven
IDEAL 61-958 SureTest Open/Closed Circuit Tracer Logo
108 people viewed this question
Top IDEAL Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an IDEAL Electrical Supply Expert? Answer questions, earn points and help others
