Question about Hardware & Accessories
I own a Maytag Dryer that has stopped working properly: Model LER6620PQ0 Serial MS3647251 Type DWJR-ELE-2406028-FM54 On all cycles, the timer moves until it is ready to stop. At that position, it keeps running (for hours). You must manually stop. At the same time, it stopped drying, meaning it does not get hot.
  • Anonymous Mar 20, 2014
    Details are as stated in the summary.
    Novelist:
  • 133 Answers
Dear Paireyes,
Things that can stop electric dryer from heating are as listed: house fuse or breaker, heating element, burnt wire, thermostat, thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug
To check various points here are the simple tips:
  1. To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.
  2. To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
  3. To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
  4. To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
Here is the link for the dryer and how to disassemble the dryer along with the images:
http://www.applianceaid.com/may-apart.html#common
Let me know if that helps. All the best :)
Regards,
Srinivas
Posted on Jun 23, 2009
  • Srinivas Dhulipala
    Srinivas Dhulipala Jun 24, 2009
    Hello Paireyes,
    Any updates? Waiting for your response..
    Thanks and Regards,
    Srinivas.
I have a Whirlpool DWJR-ELE-2406028-FM54 and when I open the door (while machine is running), the drum keeps turning. How do i remedy this?
sounds like the door switch is broken,good thing it broke in the running position or the dryer wouldn't start.that isn't a good model number either,open the door look around the opening where you put the clothes in and you should see a tag with the model number,you'll need that to order the door switch.the dwjr comes up but not the rest if this is a ge dryer.
Feb 05, 2018 | Whirlpool Dryers
Whirlpool admiral clothes dryer won't turn on. It's approx 8-9yrs old & in good condition. The Model number AED4475TQ1 Serial number MY1739210 Type DWJR-ELE-2406026-FM54
Check breaker in breaker box (30 amp). Check door switch plunger on door, check door switch. Check dryer plug in to outlet.
Sep 06, 2015 | Whirlpool Dryers
What is the capacity of a Kenmore dryer model 110 62622100
The dryer should hold what the washer will hold especially if there a matched set this one looks like a super cap. hope this helps
Feb 18, 2015 | Kenmore Dryers
Kenmore electric dryer DWJR-ELE-2406028-FM54 Model 110.64632300. when we close the door the start button doesnt work until we close it 5 or 6 times. Help.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Kenmore 64722 Electric Dryer
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
Where do you find a heating element for a Kenmore Model #110.66662500. Serial: MT0203728 Type: DWJR-ELE-2406028-FM54
Grainger.com is easy or you can look thru the yellow pages for a local appliance repair store, for parts.
Nov 10, 2009 | Kenmore 62602 Electric Dryer
It appears the heating element went out on our older Kenmore dryer - Type DWJR ELE 2406028 FM54. mod 110.62622101. Is this an easy fix?
Yes it is fairly easy to replace from the back. First verify it is the element and not the thermal fuse or a loss of one leg of the 240VAC circuit.
Eric
Jul 06, 2009 | Dryers
My Kenmore drier won't stop now! Perhaps timer isn't working?
Hi there. this is a timer issue. it counts down but, the actual shut off dial embedded in the timer mechanism is damaged for some reason. replacing the timer assembly will correct this issue. there are two parts to a timer. One, it times and last, it initiates the shutoff. the second action is not working properly. to be sure, check the relay before you purchase the new timer.
I have also provided you with a complete manual set that you can access and print out if you would like.
Click here for your manual
Click here for your instructions Guide.
Mar 06, 2009 | Kenmore 84052 Dryer
Dryer don't blow hot air, everything else runs ok.
you need to check the heating element and the thermal fuse to see if they are blown.
Dec 19, 2008 | Kenmore 659 Electric Dryer
Hardware & Accessories Logo
173 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
