Question about Bosch Classixx WFL 2066 Front Load Washer
Well here i am,back again.Same problem kind of.yesterday we took off and descaled all pipes/filter etc.It seemed to solve the problem as the first wash worked perfectly,then on the next wash.......F18
F18 AGAIN. all pipes descaled and filter too.no blockages.seems intermittent.
  • 63 Answers
Have you tried a boil wash ?
Also check that the drain pipe has no kinks or sharp bends in it.
I know we managed to get the drain pipe cleared :-)
But the next step may be to check that the waste pipe you are connecting to is not also scaled up.
If you can take the drain pip off again, check and see if the pipework you are connecting to is also clear.
Other than that, this may actually be a failing drain pump.
Check the rest of your pipes are clear in the house (where the machine is plumbed into).
Then do a boil wash - hottest wash you can, NO SOAP and empty drum.
Hopefully that will let the machine clear everything else out.
Posted on May 13, 2014
Testimonial: "Well i've done all this today and so far so good.my hubby's getting fed up with it but its working at the moment so i'm happy.Thank you so much."
Coffee maker will not prime.
E05 means "Water circuit blocked. No water in flow meter or flow meter not turning (jammed)".
Since I got it when I had not descaled for a month, I poured in tripple strength descale in the water container, and restarted the machine 3 times. Noticed that it took in a small gulp of the descale. Waited hours. Restarted 3 times again. Waited... and after about 20 restarts over 2 days. When I almost had given up it primed and was able to do a normal descaling.
I forgot to weigh how many grams of descaled it took in after each restart. That would have been nice for troubleshooting.
Apr 06, 2014 | Saeco Exprelia Automatic Espresso Machine...
Fault finding
Hotpoint wd860p washer/drier had fault code F08 come up on the display so took all the usual steps
1. Checked filter
2. Took top off machine checked all contacts
3. Circuit tested usual items
put onto cycle onto rinse and spin after rinse came up with fault code F08 again. Checked internet sites for solutions nothing matched the problem. So started again checking all usual items nothing seemed wrong whilst spending time looking over the machine I noticed the back edge of the weight block was damp? Unplugged the unit and I looked along the grey plastic condense hose which runs from water inlet supply to the heater unit for the drier and it had been rubbing on the drum causing 2 very small holes in the pipe!!!! So to test I pinched around the pipe sealing the holes with some blue tack and fixed in place with some insulation tape. Put it back on a cycle and all seems ok I can order a new pipe whilst the wife still uses the machine. It would appear most error codes are not specific to a particular problem... Typical of a money making scam for the service dept of the manufacturers ...!!!! Watch out ... Hope this is of some use...
Mar 30, 2014 | Hotpoint Washing Machines
Still problems
The symptoms would seem to indicate a blocked air filter. Just because the fuel filter is showing fuel, doesn't mean it is getting to the jets. After a complete fuel system clean it could be something as simple as some dirt in the jets of the carb. When you clean something as thoroughly as that you can still miss something.
Jun 19, 2013 | Suzuki Boulevard S40 Motorcycles
Have a 2000 kawasaki ninja zx6 bike spudders .. so I took off airbox and filter and it runs fine . Then I just took off filter and put airbox and then it sputters again . Any suggestions ? Thanx
G'day,
I have a suggestion.
It worked with no airbox( airbox lid I guess you mean).
Then I would think that your problem would almost certainly be a blockage or restriction to the air flow entering the airbox intake.
Look in the airbox,with the lid off-And see where the air enters the box- the air ducts on each side.
Make sure these are clear of any obstruction.
Check the air intake vent in the front of the fearing for obstructions.
I feel pritty sure you'll find your problem here(I hope!).
See how you go
Kind regards Andrew Porrelli
May 17, 2011 | 2000 kawasaki ZX-6R Ninja
Water is coffee is coming out very slow.. will descaling help???
Hi it sounds like it does need descaling i would do it more than once as it can build up and block the machine, once you have done this it will be back working again.
if you had no water or coffee coming out at all then i would say it has something else wrong with it like element etc, but as it is working but only slowly then descaling will solve your problem and should get it working as new again.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 25, 2010 | Keurig Coffee Makers & Espresso Machines
GAGGIA BABY. NO WATER COMING OUT.STEAMER FINE
I had exact same problemeven took entire machine apart - all fine. Solution is very simple... descale with Gaggi descaler solution. Remove filter and block, mix solution with 1.5L of water, turn on for 20 seconds, wait 20 rinse through steamer, wait 3 minutes and repeat until all solution used - rinse compeletly with clean water
Jan 19, 2009 | Gaggia Baby Espresso Machine
Saeco Incanto -- no coffee coming out
After I posted this I decided to descale the machine again, even though I'd just done it a couple of weeks ago. After descaling and rinsing I tried running water through the brew group by pressing the pre-ground button, then holding down the big cup button. Still no water, but then I turned the little knob on the coffee dispenser counterclockwise, about half a turn. It worked! I rinsed it well, then made a cup of delicious espresso.
Mar 01, 2008 | Saeco Incanto Classic Espresso Machine
Tefal quick cup - descaling problem
Push red and black for 5 seconds to lunch descale then unit resets light at end oy cycle
Hampshireman
Feb 25, 2008 | Kitchen Appliances - Others
Bosch Classixx WFL 2066 Front Load Washer Logo
99 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
