Question about Refrigerators
Kic super cool fridge
My k i c fridge rubber seal does not seal door of fridge so not keeping cold. Need technician etc to come and repair please
the dr
  • 447 Answers
SOURCE: Fridge not cool
the coil is frosted over and no air is being pushed to the fridge it may clear up after a few defrost cycles or remove the food from the freezer and allow it to thaw completely (12hrs) the ice behind the back wall takes a long time to thoroughly melt or you will have soild ice instead of frost and then it will never thaw soild ice.
Posted on Sep 29, 2007
mikedurland
  • 481 Answers
SOURCE: Maytag MSD2651HES fridge not cooling freezer works find
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
SOURCE: Hotpoint Fridge Freezer FF187e - 3 lights flashing
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Posted on Feb 24, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Fridge is not cold freezer works fine.
Try changing the damper settings in fresh food compartment. Your refrigerator has a control board and it is possible the board is no longer working correctly. If your board is bad I can help you locate one. If the fridge is still under warranty I would have the technician come out. He would possibly just change out the board without testing to original board. Other things that could cause problems are thermistor and defrost thermostat located inside the freezer and attached to the evaporator coil. If you continue to have problems, let me know, Thanks, Sea Breeze
Posted on Mar 24, 2009
SOURCE: Westinghouse virtuoso fridge/freezer has stopped
I have the same fridge (stainless steel virtuoso) and when the fridge section stops cooling you have to turn power off. Then remove everything from the freezer including the shelf. Next get a pointy object and remove the two plastic screw covers located on the back inside plastic freezer panel, Next remove the two phillips head screws securing the panel in place. Next (and this is a little tricky) get two solid forks and lever the back interior panel off, thereby exposing the cooling system of the fridge. Next get a hairdryer and completely defrost this item, and then reassemble. Switch power back on and your fridge will be fixed, and cooling like a champion! plus you have saved hundreds by not paying ripoff "technicians" I have to do this every six or seven weeks because of the high humidity here in Darwin, the freezer is "frost free" but the cooling system still ices up, and this is what blocks airflow and stops the fridge cooling.
Posted on Dec 27, 2011
Whirlpool refrigerator double door fridge Ice deposits on the vegetables in summer season when placed directly in front of the cooling panel
Humidity is the most probable culprit. Verify if it is getting in
Examine the door rubber seals to ensure tight sealing. If rubber seals worn out, you may need to replace them
May 17, 2014 | Refrigerators
Refrigerators manual
could be the door gasket is not sealing door out of alignment or a bad gasket usually
Jan 29, 2014 | Refrigerators
My kic fridge have 2 compartments. Freezer and fridge. only the fridge part dont work help please
The freezer is where the heat is removed from the box and cold air should circulate from the freezer into the refrigerator section. Something must be blocking the vent between the two. There is only one cooling unit; it cools the freezer and is also vented into the fridge for sub-freezing temperatures.
Nov 26, 2013 | Red Line Mens Classic Gmt Black Dial Black...
KIC fridge not getting cold freezer ok , regassed 30 days ago
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 27, 2011 | Refrigerators
I have a 2 door fridge, with the freezer at the bottom. My KIC fridge is 4 years old. My problem is that the freezer is cold, but the fridge is warm. I desperately need help, what cold this be ?
Pull it from against the wall, to let it breath. The condenser is usually in the back of the frige...It can also be a problem with the compressor or it's simply loosing freon. Make sure doors shut with a seal too. Try adjusting both thermostats too.
Apr 19, 2011 | Refrigerators
I own a KIC Fridge the problem is that the door does not closes the rubber does not grip tightly when closing. I have to sometimes lean on the fridge for 5-10 seconds for it to close and it sometimes does...
Hi did anyone get back to you on this? I have a KIC Fridge and it does the same... take out the top door shelf/rack but then you MUST unscrew the light (cause otherwise your light never goes off and your food doesn't stay cold) cause the top shelf/rack in the door switches off the light... anyway... once the top shelf is out, the door will close better.... not sure how else to fix it though...
Feb 09, 2011 | Smeg FAB32 Bottom Freezer Refrigerator
KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Jan 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
