Question about Canon iR 2016i Black and White Copier
What is causing blank copies on canon IR 2018 both print and copy
When i try to make copies, they come out blank. eeven the internal prints come out blank.i have checked the ros system appears. ok please assist me cos am stuck
SOURCE: Canon Printer model IR 3300 making noise while printer
Clean rollers of debris
Posted on Jun 28, 2007
SOURCE: canon IR C3220 cannot print multiple pages..ONLY able to print one page
The answer depends upon the printer controller that your 3220 has. There are at least 3 controllers & probably twice as many versions for the assorted printer controllers. The key is do you have a Fiery (Little white box hanging on the back) or does the network connect directly into the NIC on the upper left corner of the copier. Drivers with -C1  or  -C2 connote a Fiery printer driver. I would advise using the PS drivers if this is the case as the Fiery is much better at PS than PCL. Another way to tell if Fiery is on copier is scroll to right on LCD panel & see if there is a "Printer" screen. If so you can go in to "functions" "Print Pages" & print a "Configuration" page. this will show you the network ip#. Put the # in your web browser (no http:// etc needed) & you can download the correct drivers for Mac / PC right from the device. If no Fiery is on the device stick with PCL5C drivers as they are usually the best for Canon PDL board print controllers.
Posted on Jan 16, 2009
  • 67 Answers
SOURCE: Blank vertical streaks
the toner cartridge is running low on toner and it needs to be replaced
Posted on Apr 15, 2009
  • 39 Answers
SOURCE: Canon ImageClass MF 6550 prints light text
I mean can you scan a text document with the "photo" option and see if you are still encountering problem. And check this out, he tells how to reset to factory and test scanner. http://www.fixya.com/support/t342579-just_started_printing_blank_pages
Posted on Apr 27, 2009
canontech
  • 1219 Answers
SOURCE: canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Posted on Jul 02, 2010
SYSTEM ERROR E007 ON CANON iR2018
Call to 1-800-243-0019 Canon ir 2018 system error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film.
Apr 15, 2017 | Canon Office Equipment & Supplies
Blank printing ir 2018 n
There can be several reasons for your printer is printing blank pages. To help you troubleshoot the issue, please follow the link given below and follow the instructions mentioned on it:
http://canoncanada.custhelp.com/app/answers/detail/a_id/2182/~/printing-blank-pages
GuruAid.com
Jul 20, 2016 | Canon ImageRUNNER 2018 Copier : 2018...
My canon copier ir 2018 printing and coping blank copies
Are you loading the copies to be filed in the right direction. Some printers require face up for autopull, for manual opening the lid the copy should be face down.
Is the ink empty?
Oct 01, 2014 | Office Equipment & Supplies
What is the reason for blank copy in ir3300 copier
Check the fixin unit,lamps,thermistor,thermal fuse
Aug 02, 2014 | Canon IR 3300 Digital Copier
Why is my canion ir 2018 making blank copies
you coppier laser scaner unit or hi voltage power supply complaint
May 13, 2014 | HP LaserJet 4p Printer
1/3 of page blank when print, or copying
Hi Abe,
1) Press the Ink button -> Test Print -> then choose Print Quality -> the printer will then go through and print a series of small squares in each of the four colors in the shape of parallelograms. If you see any gaps in parallelograms then you will be asked asked to clean the cartridge, do so. -> Just keep repeating process until there are no gaps
2) Then I did an Alignment check right after the cleaning through pretty much same process:
Press Ink button-> Test Print -> then choose Alignment-> and make sure the patterns match to the closest number
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Brother Printer Support
Feb 10, 2014 | Brother MFC 7420 All-In-One Laser Printer
Canon ir 2018 image is lighter than darker
Hi there, I assume when you print that you would like the image to be darker? or is it when you copy?
Aug 07, 2013 | Office Equipment & Supplies
I have been using Canon IR 2018, it shows an error message "System error e007" while copying or printing though its good with scanning.....kindly suggest me some proper remedy to come over....
there is a one white patch sensor on the fixing film, if this patch sensonsor can't read by fixing unit. machines will show E007 error because of fixing film broken.
so you requie to replace fixing film.
May 10, 2011 | Canon iR 2016i Black and White Copier
Canon IR 2018 runs normally but returns a completely blank page. Copier has just been serviced and the service man removed and cleaned the laser unit.
If you have blank copies and prints, and the service man cleand laser, that means that laser unit isnt correctly in or laser shutter doesnt move.
Call him back and claim warranty
May 31, 2010 | Canon Office Equipment & Supplies
On canon iR 1020, i cannot print and make a copy
Do you mean that you have blank copies/prints, or that there is some message on display, or just blinkig red led...?
If yyou have blank copies the problem is in laser shutter.
If you have error message send detailed description.
May 21, 2010 | Canon NP 6035 Copier
Canon iR 2016i Black and White Copier Logo
133 people viewed this question
old marine
old marine
