Question about Sony HDR-HC1 Mini DV Digital Camcorder
Hdr-hc1e driver where
Where to download
    Problem Solver:
  • 7 Answers
Install the latest version of the PlayMemories Home software. It should install the drivers needed.
Check the website for download here:
HDV 1080i Handycam Camcorder
Posted on May 13, 2014
    Top Expert:
  • Sony Master
  • 75,471 Answers
HDR HC1E sony camcorder rejects every tape Moisture Condensation
hi,
i have a HVR-A1E that uses the same mechanism and it is a real s...t, i used this cam only a few times and had same problem...
i found out on blogs that is a default on those cams... i had to buy another cam to be able to read the recordings i made !
i went to this solution, i bought a FW recorder that records in real time with included battery and hard disk, because the only really sure repair is to change all mechanism (more money than buying another cam !) and must be done by a professional because the mechanism is extremely sensible to mount and adjust !
i tryied many things: let the door open for a long time and then reboot, try to move a little gear that is the responsible of the problem, putting a bit of mechanic oil, and nothing worked !
the problem comes from a little gear that have troubles to move correctly, and this gear is also activating a sensor that says to the main board, that the door is well closed or not...
cheers,
mich
Oct 10, 2012 | Sony HDR-HC1 Mini DV Digital Camcorder
HELP ME PLEASE
If moisture condensation has occurred, remove the recordable media (tape) and then turn off and leave the media compartment open for the hour the camcorder is turned off . The camcorder can be used again if the warning indicator does not appear when the power is turned on again.
Moisture condensation normally occurs when the camcorder is brought directly from a cold place to a warm place. It can condense inside the camcorder, on the recording media, or the lens and cause a malfunction.
To prevent moisture condensation when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and seal it tightly. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature.
Oct 25, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Camera LCD screen
Perform the following troubleshooting steps and check whether it helps;
1. Check whether the issue persists with all the tapes. If the issue persists with a particular tape, the issue is with the tape. change the tape. 2. Check whether the battery is fully charged, 3. If the batteruy is nit fully charged, connect the Camcorder to the wall outlet using the supplied AC adaptor. 4. Then, reset the Camcorder by pressing the RESET button using a sharp-pojnted object while it is turned ON.
5. If the issue still persists, remove the battery pacjk and disconnect the Camcoredr from the wall outlet; then slide the power switch to ON position for at least 30 seconds. Then reconnect the AC adaptor to the Camcorer after 1 minute.
If the issue still persists, service may be requuired. Please cointact ur Camcorder manufacturer to get it serviced.
Oct 15, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Computer does'nt reconize Sony handycam HDR-HC1E
You need video editing software in order to capture video. You can download free software or trial software on the internet. If your using windows you may check to see if your PC has moviemaker on it. Not my favorite, but if your new to this, then it will work.
All PC's these day's have firewire inputs, but that doesn't necessarily mean you have the video drivers and software to communicate with your camera. Most Camera's don't come with video editing software.
I recommend SOny's Movie Studio for $129. It's worth the money and fairly easy to use.
Sep 03, 2009 | Samsung SC-D453 Mini DV Digital Camcorder
The lcd screen is almost black/ very dark, but i still see that it works. it looks like the light is out. sony hdr hc1
The LCD screen may be turned OFF. To turn the LCD backlight off or on, press and hold the DISPLAY/BATT INFO button for a few seconds. After the backlight has turned off or on, release the button.
Aug 07, 2009 | Sony Handycam HDR-HC1E HDV Digital...
My Sony HDR HC1 will not power on.
this is some problem with the internal software or hardware. nohting to do with externals. check it out by doing a hard reset.
Mar 09, 2009 | Sony Handycam HDR-HC1E HDV Digital...
My Sony HDR-HC1 NTSC will not power on.
What if there's no tape inside of the camera, does it still same?
Feb 09, 2018 | Sony Handycam HDR-HC1E HDV Digital...
Sony camcorder has knocking noise in recording or playback
Try using tapes of different sizes. a big tape may be exerting stress on the mechanism
Feb 27, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Sony HDR-HC1 Mini DV Digital Camcorder Logo
108 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
