Spinner not moving after washing
The spinner is not working after washing
    Problem Solver:
  • 6 Answers
Coupling in side agitator not in gaugeing remove agitator and replace plastic coupling
Posted on May 14, 2014
Bottom rotor is not working
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-yourselfer can fix it; here's how.
TOOLS NEEDE TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,New drive belt (if necessary),New drive motor (if necessary)
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Nov 08, 2011 | Washing Machines
Washtub will not move
5
6
Feb 04, 2011 | Washing Machines
Maytag Atlantis Model 8551AWW washing machine...fills up with water...then starts the agitation cycle and will agitate for about 1 minute...then shuts off...after about five minutes the agitation cycle...
5
6
Read more: How to Fix Washing Machine Spinner ' eHow.com http://www.ehow.com/how_2092465_fix-washing-machine-spinner.html#ixzz2JXhQRhyW
Feb 03, 2011 | Maytag Atlantis MAV8551 Top Load Washer
I was trying to clean the washer and i took out the Augger and can't figure how to put it back together.
by auger do you mean the agitator here is a schematic of your machine of how the agiator installs into the machine if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future with similar situations
here is your schematic http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fM0606007-00007.png
Thanks Rick
Feb 03, 2011 | Maytag PAV2300 Top Load Washer
My washer had stopped spinning about two weeks ago, we replaced thecoupler and it worked fine but today it stopped spinning again
5
6
Feb 03, 2011 | Washing Machines
Danby twin washer/spinner
should have a belt idler or tensioner between the motor and the drum
Sep 13, 2009 | Danby DTT420 Top Load Washer
WASHER SPINNER DOES NOT WORKING PROPERLY
normal operation of a two piece washer agitator is the bottom section goes back and forth and the top section goes in one direction like a ratchet.(slips one way and locks the other way)
Jun 13, 2009 | Washing Machines
Washing machine does'nt work when switch on ,but the spinner work.i want to know what's the problem
Washing machine 7.0kg. Does not work when switched ON. The on light does not stay at Fuzzy program as it used to be but it jump straight to Delicate program.The washing machine does not move move at all even when I press the Start button.
Oct 28, 2008 | LG WFT1071TP Top Load Washer
To repair my Haier washer
its hard to know without seeing it but check the belt,carbon brushes if it has them,not sure where to get parts
Feb 29, 2008 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
