How to fix the spin lock
After washing the spin does not on.
  • 4 Answers
Slim chance are that the motor winding is broken, electric motor capacitor is dry or the control module is defected.
I would first make sure that the water level in the drum is below the level that will stop spinning from taking place.
If water level is high, check your filter and pump cover. make sure that no coins or other items are not blocking the pump.
If water level is low, you need to check your pressure switch (connected with a rubber tube to the bottom of the drum).
Good luck.
Posted on May 13, 2014
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Washing machine washes then will not spin HELP HELP dirty clothes
When you set "the timer to drain and spin only". After "drain" program finished - not pump or motor sound or all sound stoped, the machine is freeze?
The meaning is sometimes, the sensor of water level doesn't working properly. The "drain" program is keeping running.
May 27, 2017 | Washing Machines
I have a FEX831FS4 washer/dryer. The washing machine will wash and spin, but will not rinse and spin. Lid is locked.
think ur voltage is too low..usually frigidaire brand washer is 220v,..usually starting of spinning has a high ampere and it need a high volt electrical supply..try to check ur main breaker for washer only..ur lid lock will lock after 10secs when it spin fast...
Dec 02, 2012 | Washing Machines
My Frigidaire Crown Series top load washer was agitating but would not spin. It did drain the water. The lid lock did lock when it was in the spin position. It was smelling like burning belt so I...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 20, 2011 | Frigidaire Washing Machines
We have a Kenmore Series 80 Top Load washing machine. The problem we have is that after it washes the clothes, it won't spin. Can we fix it?
Sure you can fix it. I suspect you have a broken lid switch. To repair it you flip up the controls. Unplug the lidswitch. Pop the S-clips and remove the case. You can now replace that lid switch. If it turns out to be ok you might want to look inside the pump for objects that can lock it up. If it is locked up the tub will not spin. Why? Because the pump is mounted directly to the motor. If it pumps but don't spin then look for a broken drive coupling. None of this stuff is difficult to repair. I have videos of all these fixes and a service manual HERE.
Kenmore Top Loader Blues
Oct 17, 2010 | Kenmore Washing Machines
FRIGIDAIRE AFFINITY LTF600 FSO PUMP KEEP,S RUNNING AND WONT SPIN
I fixed mine by replacing the door lock they are about 50.oo
The door lock has two locks, one is instant when you push start the other is a time lock, so you cant open the door for a little if you stopped it during the spin cycle. The problem is what they call the WAX switch or heater. When power is applied to this WAX lock it takes 30 to 60 sec. to lock and to unlock when power is removed.
The machine will not spin, if this lock is not working correctly.
You cant bypass it by jumping the power from one side of the shitch to the other. The board moniters the power draw and when the switch closes the lock contacts. You can how ever open up the lock very easy and bend the contacts closer to get you by for the weekend. unplug washer, remove the two screws on the back of the top panel behind the washer, remove top, open front door and remove the two screws that hold the lock, reach in an pull up the lock, remove wires, now open up lock and bend the piont contacts in side or install new switch.
Aug 07, 2010 | Washing Machines
Door not locking nor spin cycle not working
Hi.
Before proceeding to spin the timer does a check on the lid switch.
You should be able to fix the problem replacing the lid switch.
Regards.
Ginko.
Jul 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Tub sometimes will not spin to wring out clothes.
Sounds like the machine is not pausing between cycles to allow the transmission to lock into spin.
Eric
Jul 02, 2009 | Kenmore Washing Machines
Not spinning out, all icons flash, so therefore door remains lock
This is a major control fault within the chip set on the main control board. replacing this damaged control will fix this issue you are having at this time.
Jun 13, 2009 | Washing Machines
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
