Question about Toys
Just bought a used rig to use as a water truck. Drove 5-6 hours home and it started running a little off, not wanting to accelerate, etc. The next day I drove it the following 2-3 hours home and it even died on me once. I changed the filter and it ran great for a day and then started the same symptoms again, running bad, and even dying again. I have replaced the filter 2-3 times now and it's always a temporary solution. Any idea what's causing this? I brought to a shop but they couldn't tell me anything after having it all day. Said it was the injectors but when I got there it wouldn't show on their computer. Would it be getting temporarily better if it was bad injectors or are these guys just trying to get big money out of me? What does it sounds like is wrong with it?
  • Toys Master
  • 3,895 Answers
Bad fuel maybe in fuel tank. Maybe moisture or water in fuel tank ?
Google Mentholated Spirits and water in fuel
Posted on Mar 18, 2017
SOURCE: truck starts, dies. truck runs good some days,bad the next
I had the same problem with My 1990 F150 300 6cylinder 4x4.....I cahnged all the same things you did, finally I sprayed a can of Gumout through the throttle body and it worked and ran great. Now I add fuel injector cleaner to the gas and a regular clean with the gumout and the problem has'nt come back. Good Luck to you and hope it works!
Posted on Oct 06, 2008
SOURCE: engine intermitantly stalls
if this a fuel injected car just check to fuel pressure first.
Posted on Oct 24, 2008
SOURCE: BladeZ 40cc go-ped doesn't strart... well kinda
clean the carb and make sure it adjusted right
Posted on Feb 06, 2009
  • 1959 Answers
SOURCE: Dies after running about 2 minutes
It's got all the symptoms of a leak in the fuel line. You may want to start backward at the tank and work your way all the way to the carb to find it but it would be surprising if it was something else. All the best.
Posted on Jun 15, 2009
SOURCE: 1992 Roadmaster Estate 5.7 liter dies for no reason.
Hey I have a 1993 Buick roadmaster also. Had exact same problem. It turned out to be the fuel pump. It was going bad and would work fine then cut off and then back on. Took me 6 months to figure it out. Every time I took it to the mechanic it would work just fine so I put a full tank of gas in it and told him to drive it and it died after a few days. Was a real headach. Hope this helps.
Posted on Sep 27, 2009
Why is there oil in my radiator?
Possible head gasket but it would still run but overheat lots of smoke from exhaust or you have a leak from transmission or oil lines in radiator. If too much sludge is running in your engine jackets, may be seizing engine. Those are worse case scenarios. But always start with obvious protocol why it is not starting. Spark, charge, fuel, oxygen. You may have a simple fix with old contaminated antifreeze. Antifreeze needs to be replaced every two years.
Jun 05, 2014 | 1994 Pontiac Bonneville
96 Benz ran out of gas other day, got it filled up & drove home (20 miles). Next day drove about 40 miles, left car running in park for about 15 min, when I left car was stalling like it was running o
You never leave a car running, as it will
overheat the Exhaust Converter
When you run out of fuel, you sometimes
ruin the Fuel Pump
It depends on gas to lubricate it,as strange as it sounds
Check fuel pressure & volume at the motor with a gauge
Jul 20, 2013 | Cars & Trucks
H I have a 2000 Audi a4 1.8t I drove it home from guys house bout hour and half away for next week I started and drove around the block car did get low on fuel but never shut off or any problem them next...
Sorry VW dealer only as i think this car you bought had a immobilisor problem which is why it was sold ,could be a fuel pump or a coil pack but i have a funny feeling in my water this vehicle has a immobilisor as i have come across this before just like this ,runs well then it will just not start
Oct 13, 2012 | Cars & Trucks
On my trip form Houston to San Antonio last saturday around 2pm in the afternoon, While driving at over 70 mph constantly for about 1 hour the engine light came on and the red flash siymbol came on in my...
go t auto zone and have them run a diagnostic for free when the light is on , that will tell you the problem easy , or you can buy an OBD scanner,
Jul 25, 2011 | 2004 Dodge Ram 1500
I bought a 92 accord LX that was sitting in a lot for 5 yrs. Towed it to my house and replaced the battery and alternator and she fired right up. Drove it for about 30 miles and parked it overnight. the...
dont think timing is jumping as you describe but more like the advance unit on the distributor ,advance timing and it will start but when cold zilch had this before more than once and on more than one make of vehicle ,favourite for this is the old land rover discovery with teh V8 engine ,pull vacumn pipe off the inlet manifold for the advance unit and **** on and you you will see what i mean ,**** and put tongue on end of pipe and it will lose the **** ,.
Mar 13, 2011 | 1992 Honda Accord
The 12 volt battery(LUCAS 065/3) on my FORD FIESTA 1100cc is 4 years old, in that time i have only driven 1,600 miles as my journeys are usually very local. I make sure i use the car twice a week to keep...
Running so few miles has accelerated the aging of the battery - the battery never had a chance to fully recharge in such small trips -  so now you have to replace it a year sooner than usual.
Just replace it.
Aug 28, 2010 | Ford Escort Cars & Trucks
Check engine light stays on.
You've made the correct decision. Let the dealership diagnose the issue. They'll tell you EXACTLY what the problem is and what's needed to fix it (parts, labor, tax, time-frame, etc.).
Jun 04, 2009 | 2006 Hyundai Sonata
I have a 1999 buick regal ls dying.
Check the harmonic balancer
May 26, 2009 | 1999 Buick Regal
Toys Logo
1,272 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
