Question about HP Smart Buy EliteBook 850 G1 Intel Core i5-4200U Dual-Core 1.60GHz Notebook PC - 4GB RAM, 500GB HDD, 15.6" LED HD, Gigabit Ethernet, 802.11a/b/g/n, Bluetooth, Webcam, Fingerprint Reader, 3-cell 24 WHr - E3W20UTABA
Hp compaq unable to boot from usb - HP Smart Buy EliteBook 850 G1 Intel Core i5-4200U Dual-Core 1.60GHz Notebook PC - 4GB RAM, 500GB HDD, 15.6" LED HD, Gigabit Ethernet, 802.11a/b/g/n, Bluetooth, Webcam, Fingerprint Reader, 3-cell 24 WHr - E3W20UTABA
Hp compaq nc6230 boot from usb
Most PCs will not boot usb, unless the CMOS setup configure supports that device as a boot choice on cold start. F10 or does allow whatever key strokes needed before windows logo, will get you into CMOS config. Then look for boot, sequence and see if the usb is an option, if not, no hope for usb boot.
If CMOS config does allow usb boot AND your usb device has been set up to be a boot device,(and you saved the cmos changes) with the proper files...
shut dow, put in usb and cold start.... save
Jan 28, 2014 | HP Compaq nc6320 Notebook
USB device should be recognized in the bios and make it first boot at the bios boot option menu.
Just plug in the usb device before turning on your computer.
Mar 05, 2013 | HP Presario Computers & Internet
How to boot from flash disk compaq evo n1000v
If the BIOS configuration for the boot order does not have an USB device in the list then this model laptop cannot boot up from an USB flash memort stick.
Aug 25, 2011 | HP Compaq Evo N1000v Notebook
How to unlock password for a HP 2140 Mini-Note
If you are talking about the login to Windows password then here is one way to do it:
Create a bootable USB stick using this tool: http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
Use the image from Ophcrack to load onto the USB: http://ophcrack.sourceforge.net/download.php Choose the XP LIVE CD Option
1. Download the YUMI exe to your desktop 2.. Save the LIVE CD of Ophcrack to your desktop. 3. Plug in the usb stick you want to use (make sure it is at least 500MB. 1GB if possible) 4. Run the YUMI EXE and follow the instructions. Make sure to choose the USB Drive Letter ("D:" E:" etc) 5. Choose the Ophcrack ISO for the image. 6. Install to USB 7. Click Finished and exit the program and close any other open programs. 8. Restart the computer. Leave USB plugged in. 9. As soon as the computer restarts, tap the F10 button to enter the BIOS Menu. 10. Scroll to the Boot / Advanced Menu and change the boot order to USB first, HDD second. 11. Save and exit BIOS. Computer will restart. 12. Once booted up the computer will bypass the HDD and boot into the USB 13. elect Ophcrack from the list and hit Enter. 14. Follow the on-screen instructions to have Ophcrack force the password.
(If you're using Linux then use the Linux LIVE CD Image instead of XP)
May 03, 2011 | HP Mini 2140 Notebook
I am Ravichandran, using HP Compaq nx6100 Model Laptop. My laptop did't boot and not even entering into Bios. Only HP Invent Embalam will appear and press F10 Rom Setup. If I press F10, F9, F1 there is...
If you are unable to "F-10" at power up, try 1}. unplug your laptop from AC adapter.
2}. press and hold power button until the computer powers up and powers off.
3} remove battery.
4). press and hold power button 10 seconds then release, replace battery.
5}. power up and press F10
If you are still unable to access BIOS you will need to obtain a system restore disk from HP
Apr 26, 2011 | HP Compaq nx6110 Notebook
Hi, I want to replace windows with Solaris. Im unable to change the boot sequence. Please give me the detailed explanation.
If you enter the BIOS menu just before the system boots up, you can choose whether to boot from DVD ROM, LAN, USB etc. Just select what you require and save it.
Dec 19, 2010 | HP Compaq nc6000 Notebook
How do i boot a compaq proliant dl380 with a usb drive set up for booting?
Make sure you have turned on the USB Boot in the BIOS of the os. Once this is done, select the order you would like for the server to locate boot files. (Hard Drive, USB, CD/DVD, etc.) Once complete, insert the USB and reboot the server.
Good Luck
C2S
Jun 30, 2010 | HP Compaq ProLiant DL380 G2 Server
An you boot from usb drive using HP Compaq d220
Check the BIOS for boot options, if it has USB listed you should be able to, you will need to make the USB bootable as well, theer are instructions here: http://www.bootdisk.com/pendrive.htm
Hope this helps, if so please rate my solution accordingly. Thanks, David
Mar 18, 2009 | Compaq D220 PC Desktop
I can't format my 32gb pen drive.Window unable yo format it
Try to use this program to format it.
Utilityfor formatting and creating loading USB Flash (it is supported NTFS,FAT, FAT32). It works with the devices through port USB 2.0. For theload from flesh in BASIC INPUT-OUTPUT SYSTEM Setup it is necessary toestablish as the first loader USB-HDD Device. m_right_m.gif banner_header m_right_m.gif VERSION: 2.1.8 Rev. A
DESCRIPTION:
This SoftPaq contains a Windows-based format utility for the HP Drive Key or
DiskOnKey USB 2.0 device.
PURPOSE: Routine
SOFTPAQ NUMBER: SP27608
SUPERSEDES: SP27213, SP27135
EFFECTIVE DATE: May 17, 2004
CATEGORY: Driver - Storage
SSM SUPPORTED: No
PRODUCT TYPE(S):
Desktops
PRODUCT MODEL(S):
HP Compaq d220 microtower: All Models
HP Compaq d230 microtower: All Models
HP Compaq d240 microtower: All Models
HP Compaq d248 microtower: All Models
HP Compaq d330 desktop: All Models
HP Compaq d330 microtower: All Models
HP Compaq d330 slim tower: All Models
HP Compaq d338 microtower: All Models
HP Compaq d530 convertible minitower: All Models
HP Compaq d530 small form factor: All Models
HP Compaq d530 ultra-slim desktop: All Models
HP Compaq d538 convertible minitower: All Models
HP Compaq d538 small form factor: All Models
HP Compaq dc5000 microtower: All Models
HP Compaq dc5000 small form factor: All Models
HP Compaq dc7100 convertible minitower: All Models
HP Compaq dc7100 small form factor: All Models
HP Compaq dc7100 ultra-slim desktop: All Models
HP Compaq dx2000 microtower: All Models
HP Compaq dx6100 microtower: All Models
HP Compaq dx6100 slim tower: All Models
HP Compaq dx6120 slim tower: All Models
HP d325 microtower: All Models
HP d325 slim tower: All Models
HP RP5000: All Models
N/A: All Models
OPERATING SYSTEM(S):
Windows XP Home Edition
Windows XP Professional
LANGUAGE(S):
Global
ENHANCEMENTS:
New Windows-based interface. (For DOS-based interface, download SoftPaq
SP27214.)
FIXES:
- Allows creation of a FAT32 volume larger than 32 GB.
- Fixes installation issue where installation process stopped after the earlier
version of software was uninstalled and the new software was not automatically
installed. The installation process now restarts automatically to install the
new software after uninstalling the older version.
PREREQUISITES:
- Requires an HP Drive Key or DiskOnKey device plugged into a USB 2.0 port.
HOW TO USE:
1. Plug the HP Drive Key device into an available USB 2.0 port.
2. Download the SoftPaq .EXE file to a directory on your hard drive.
3. Execute the downloaded file and follow the on-screen instructions. If
prompted to overwrite any files, answer Yes to all to continue installation.
http://www.maxiwarez.com/2007/12/21/hp_usb_bootable_format_tool_v.2.1.8.html
Dec 30, 2008 | Kingston Technologies 512MB DataTraveler I...
Compaq V2000 freezing
Please select F1 to boot the Notebook into windows. If it is not booting then please try to boot the Notebook into safemode.
Restart the Notebook and keep pressing F8 key the select Safe mode to boot. If the issue persists in Safe mode. To isolate whether the issue is with the software or hardware. Please restore the Notebook to factory settings. Before restoring the Notebook backup your data.
If you are unable to restore, I am afraid that you need to take the Notebook for repair.
Thanks
Jul 31, 2008 | HP Compaq Presario V2000 Notebook
HP Smart Buy EliteBook 850 G1 Intel Core i5-4200U Dual-Core 1.60GHz Notebook PC - 4GB RAM, 500GB HDD, 15.6" LED HD, Gigabit Ethernet, 802.11a/b/g/n, Bluetooth, Webcam, Fingerprint Reader, 3-cell 24 WHr - E3W20UTABA Logo
20 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
