Question about RTO Garden
Honda xrm 110 bolt torque specs in engine block
  • 25 Answers
SOURCE: 87 samurai bolt torque specs for engine
The haynes book is not recommended since there are numerous mistakes and they still will not update. One of the biggest is the firing order.
The factory service manual is the only way to go.
Head bolts - 46 - 50.5 lbs (there is an order sequence for the bolts)
Intake & exhuast manifolds- 13.5 - 20 lbs
Flywheel - 41.5 - 47 lbs
Clutch cover - 13.5 - 20 lbs
Posted on Mar 17, 2009
chuck943
  • 783 Answers
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
  1. 20 Nm (15 lb-ft).
  1. 40 Nm (30 lb-ft).
  1. 50 Nm (37 lb-ft)
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
  • Tighten to 40-50 Nm (30-37 lb-ft).
  • Rotate an additional 175-185 degrees.
  • Go to next bolt in sequence.
Short Bolts:
  • Tighten to 20-30 Nm (15-22 lb-ft).
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
Posted on Mar 19, 2009
  • 3567 Answers
SOURCE: torque specs for cam on 2006 honda crf250r
Rock the caps around to make sure the bearing locating clips are lined up. Torque the bearing caps to 12 foot-pounds. At this point you must check the valve clearances again. If any are off, the cam must be removed and the correct shims installed.
Please rate this solution. Thanks!
Posted on Apr 07, 2009
polarcycle
  • 1392 Answers
SOURCE: head bolt torque spec
Always use new head bolts.
1)tighten to 40ft/lbs
2)back off 1/2 turn
3)tighten back to 40ft/lbs
4)tighten an additional 90 degrees
5)tighten an additional 90 degrees.
Posted on Aug 16, 2009
  • 12 Answers
SOURCE: head bolt torque specs for 200 honda accord 3.0
its a three step process 1st 29ft/lbs 2nd 51ft/lbs 3rd 72.3ft/lbs
Posted on Apr 25, 2010
Honda xrm 110 headlight diagram
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
Honda xrm 110 headlight diagram Google Search
Honda Motorcycle Wiring Diagrams
Honda Xrm 125 Service Manual Free Download stream video download
Honda XRM 110 Wiring Diagram Circuit Wiring Diagrams
http://spacinpauche.guildwork.com/forum/threads/578f4001002aa815f9f8aa16-honda-xrm-parts-catalogue-pdf
Aug 03, 2017 | Honda Motorcycles
Torque settings for main and bigend bearings
First you need to know the diameter of the bolts and the type of thread ie 3/8 N/C or 5/16 N/F then look at the type of bolt ie plain steel or high tensile SAE grade 3, 4, or 6, once you know this go to a general purpose bolt torque chart, and derive the torque spec info.
If the engine block is cast iron use the full torque specification.
If the engine block is alloy then reduce the torque spec 10%
Below is an example of a general purpose bolt / nut torque chart
May 03, 2016 | 2011 Ford Fiesta 1.4
Cylinder head to engine block torque sequence and ft lbs
    images for Cylinder head to engine block torque and ...
    More images for Cylinder head to engine block torque and sequence
    Small Block Chevrolet V8 Engine Specs ' Torque Specs ...
    boxwrench.net/specs/chevy_sb.htm
    their specs. Click Here! 3/8 Connecting Rod Bolt, Engine Oil, 45 ft-lbs. 11/32 Connecting Rod Bolt, Engine Oil, 35 ft-lbs. Cylinder Heads. Engine oil. (blind hole).
    [PDF]
Nov 29, 2015 | Cars & Trucks
What are the torque specs for head 1994 Plymouth acclaim 2.5
  1. Step 1 - tighten all 10 bolts to 22 ft. lbs. (30 Nm).
  2. Step 2 - tighten all 10 bolts to 45 ft. lbs. (61 Nm)
  3. Step 3 - re-tighten all 10 bolts to 45 ft. lbs. (61 Nm)
  4. Torque bolts No. 1 through 6 to 110 ft. lbs. (149 Nm)
  5. Torque bolt No. 7 to 100 ft. lbs. (136 Nm)
  6. Torque bolts No. 8 through 10 to 110 ft. lbs. (149 Nm)
  7. Re-tighten each bolt to its proper torque. Pay special attention to bolt No. 7; it should not be over tightened.
Feb 26, 2015 | Plymouth Cars & Trucks
Xrm110 engine diagram
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Xrm110 engine diagram Google Search
Honda XRM 110 Wiring Diagram Schematic Diagrams
Honda Xrm 110 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-xr-owners-manuals
Feb 23, 2014 | Honda Motorcycles
XRM 110 transmission diagram
Hi Jessrsubida, I am sorry you can't find the first and best tool you ever bought for your Honda but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
PARTS MANUAL HONDA XRM 110
Oct 17, 2012 | Honda Motorcycles
Honda vt 1100c engine bolt torque spec chart
Hi, Anonymous these are metric torque specifications in the most common sizes and are measured in foot pounds.
Bolt size___Grade 4.8__Grade 8.8__Grade 10.9__Grade 12.9
6mm__________5__________8_________12_________15
8mm__________11_________20________30_________35
10mm_________21_________40________60_________70
12mm_________37_________70________105________120
14mm_________60_________110_______165________190
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Torque specs for left crank cover VT1100C
exhaust stud torque specs
Honda shadow vt1100 Owners Workshop Manual
Honda VT1100C2 Owner Manual Page 3
Sep 04, 2012 | Honda VT 1100 C Shadow Motorcycles
Garden Logo
65 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
