My sharp tv operation system is off how to turned on
    Top Expert:
  • Televison & ... Master
  • 75,462 Answers
Do you mean the set does not Power On? If so, check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Posted on May 13, 2014
How do I adjust the vhold on the sharp 32u-s80? My screen is flipping
[PDF]32US60 Operation Manual - Sharp Electronics
files.sharpusa.com/Downloads/.../tel_man_32US60.pdf
Sharp SolarEvery SHARP Color Television set is tuned and adjusted for proper color and ... serious injury to a child or an adult, and serious damage to the equipment.
SHARP 54GS-61S OPERATION MANUAL Pdf Download.
www.manualslib.com > Brands > Sharp Manuals > CRT TV > 54GS-61S
Sharp operation manual color television 32u-s50b (48 pages) .... view the all functions implemented in your TV set demonstration and set the CHILD LOCK. 1.
SHARP 32JF-77H OPERATION MANUAL Pdf Download.
www.manualslib.com > Brands > Sharp Manuals > TV > 32JF-77H
Dec 21, 2015 | Sharp Televison & Video
How do I replace fuse?
Sharp LC46D43U - Aquos - 720p LCD HDTV Service Manual
www.manualslib.com > ... > Service manual
Flat Panel TV Sharp AQUOS LC-46D82U Operation Manual. Sharp flat ... Flat Panel TV Sharp LC46SB54U - LC - 46" LCD TV Operation Manual. Operation ...
Sep 11, 2015 | Sharp Televison & Video
Sharp 70 lc70le847u . When turning tv on unable to change channels and remote will not work. Must turn tv on and off several times for tv to operate. After that digitals channels are non exitant. Must...
It sounds that the main system control memory IC has damaged. Do a reset to this set and check. Refer its user manual to know how to make it a hard reset.
Jan 16, 2013 | Sharp 70" Quattron LED Smart 3D TV -...
Sharp remote quit working. Lights turn on, could it be the tv's problem? Ga724wjsa
Another way to verify if the remote is working is use your phone or camera to look at the IR eye of the remote while pressing a button you will be able to see a red light everytime you push the buttons to make sure the remote isnt just faulty. For any Sharp TV do it yourself TV repair call us in Centennial, Colorado.
Jun 02, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Hi.How can I connect SHARP HT-SB400 sound bar system to TV SAMSUNG UE40C6000 LED? I have RCA cable supplied by sharp, it's that possible? My SAMSUNG operation system is : T-VAL6DEUC-1016.0
You should be able to connect these but you'll need some extra adapters/converters/cables. The Sharp HT-SB400 has analog audio inputs (http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/product-details.htm?product=HTSB400&cat=10500 ). The Samsung UE40C6000 LED TV has a digital (optical) output and a headphone jack (http://www.samsung.com/uk/consumer/tv-audio-video/television/led-tv/UE40C6000RKXXU-spec ).
With a RCA (F/F) to 3.5 mm (M) adapter, you may be able to connect the headphone audio out to your sound bar directly. This is an example: http://www.cyberguys.com/product-details/?productid=4730 . I'm not sure if this will automatically disable the TV speakers.
The other option is to get a digital audio to analog audio converter. One of these is http://www.amazon.com/Digital-Audio-Analog-Converter/dp/B0013LWK3A . You'll also need the optical digital cable in addition to the RCA audio cable that you have. With this you'll have to follow the manual for turning on the digital audio output on the TV (under the Sound menu) and turn off the TV speakers.
I hope this helps.
Mar 04, 2012 | Sharp Audio Players & Recorders
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
We have a Sharp 25J-M100 and we cannot turn off the Closed Caption. We hit menu on our Sharp Remote Control and go down to Closed Caption and make sure it is off. The words never go off of the screen. Our...
If the captions are turned off on your TV, they have to be coming from your cable box. The TV is just displaying what it's getting. Check your cable box menu and make sure captions are turned off there. Cable boxes, especially on digital systems, can prevent the TV's caption decoder from operating properly. So they need to be able to provide captioning, and I suspect you've turned it on somehow. Comcast should be able to tell you how to turn off captions if you can't figure out the menus.
Jul 15, 2011 | Televison & Video
I ve got a sharp aqueos tv i turned oevr channels
Try this: unplug the power cord from the wall, let TV set stand for AT LEAST 30 minutes, then plug back in and and see if the TV operates as normal.
Sometimes this works and sometimes it doesn't.
Good luck !
Jan 09, 2010 | Sharp 25N-M100 25" TV
I need to receive a manual on the operation of my sharp tv
I believe your TV is a LC-32SB24U, not LC-325B24U.
You can download a manual at www.sharp.ca/manuals
Feb 21, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Region codes
dvd players are suitable for all regions but the pins may vary region to region
May 13, 2008 | Sharp DV-NC200
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
