Question about Miele Freezers
Why are bars flashing? - Miele Freezers
Having restarted my upright Freezer how long will it take for the flashing red light to stop flashing
what was the reason for the trouble code --if problem not fixed trouble light will keep flashing if light flashing due to temp when setting is reached will stop
Jul 17, 2016 | AEG 10.35 cu. ft. / 293 liter Upright...
Controller flashing
Hi
Check your defrosting elements and sensors.
Feb 09, 2014 | Samsung RS263TDRS 25.5 Cu. Ft....
Fridge water sound
This kind of noises produced gas in cooling system.
In the old coolers never heard sounds like streaming water because the compressors were very loud due to high pressures (12 bars or more), which were required for efficient cooling. Today we use more ecological gases which work (from 5 to 6 bars) at much lower pressures, thus compressors produce much less noises and now suddenly we hear sounds that never before heard. Generally speaking noises is lower, measured in decibels.
Dado
Feb 01, 2014 | AEG Freezers
In the control panel apear two bars like this - -
You have a code error that needs to be fixed. Call either your mfr or refer to manual or google the problem , include. Model # and code .
Feb 07, 2013 | Sub-Zero 700 Refrigerator Freezer...
How do you activate the flash defrost function on a Kenmore 16082 model? I can't find any flash defrost button.
Hi
Not all these models were fitted with a flash defrost plunger, if fitted it is inside the lid on the left hand side.
You will need to remove all the product from the freezer and store it elsewhere.
1. Pull out the flash defrost button
2. Put a chock of wood or similar to prevent the lid from closing (if the lid closes it will stop the flash defrost)
3. Wait until all the ice has melted then clean out the casing, some of these models have a drain plug in the base, (put a shallow tray under the outlet to catch the water) others you will need to mop out the water.
4. Push in the flash defrost button and wait for a couple of hours and then you can reload the freezer.
If there is no flash defrost button then follow the above instructions after you have emptied the freezer, all you need to do is switch off and unplug the freezer then go to 2. above. When finished plug back in and reload.
Regards
Gordon
May 05, 2011 | Kenmore Chest Freezer 16082
I have a Frigidaire freezer that I bought in 1994. It's a 17 cubic foot upright, model #FFU17M6AW. I need to replace one of the brackets that hold the bars for the door shelving in place. It's a plastic...
you can most likely order this part from marcone appliance parts or allbrands appliance parts they both have websites and both mail to your door marcone will most likely be able to steer you in the right direction hope this helps
Jul 13, 2010 | Frigidaire Freezers
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
Taylor 1999, series 754, 3phase ice cream dispenser freeze up
I have had this with other Taylor machines. The rear drive bearing has a pin driven into the coupling that turns the beater bar. This pin will shear off. The pulley will turn and give the illution that the beater bar is turning but it really isn't. With the unit unplugged, try holding the beater bar still and try turning the large drive pulley.
I have also had situations where the hex piece that the drive shaft goes into, was rounded out. As soon as the mix go a little firm, the beater bar would stop turning but the rear drive assy didn't.
Check this out and let me know.
Jul 07, 2009 | Freezers
Flashing red light
red light flashing on servis fridge freezer
Mar 19, 2009 | Freezers
Freezer light flashes
If its a neon lamp then the flashing might be normal
Dec 24, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezers Logo
62 people viewed this question
Top Miele Freezers Experts
John Tripp
John Tripp
Jay Finke
Jay Finke
ray gallant
Are you a Miele Freezer Expert? Answer questions, earn points and help others
