What is this is #30 when i set the aircon for warm temperaturs
06 Grand a vitara v6 overheating on open highway. Didn't do it in traffic or stop lights. Had aircon on as it was a hot 38 degree day. Aircon would get warm as temperature gauge went to red. Went back to...
bubbling when the coolant is full indicates a head gasket problem. have a compression test done to check for gasket/cracked head. have a flow test done on the radiator as the cores may be blocked reducing coolant flow.
Nov 07, 2014 | 2006 Suzuki Grand Vitara
The tv screen is not coming on hence no radio and no aircon. it only comes on when the outside temperature is really hot around 30 degrees celcius .what could the problem
Sounds like a dry joint in the circuit somewhere - possibly the power in/out join by the sounds of it. When the temp heats up, it expands and then makes a good connection, but when cold, it contacts and lifts off the circuit board. Common problem with electronics.
Dec 22, 2017 | 2003 Nissan Primera
The model is ford fiesta fresco year 1994
the fan comes on when the engine temperature exceeds fan switch setting or fan will work when aircon is on
May 11, 2014 | Cars & Trucks
Cannot set correct temperature with remote
the 16 on remote is the set temperature not the room temperature.
Jan 25, 2014 | Heating & Cooling
My Conia aircon CA24003 model is not cooling down. I set the temperature to 24 degrees C but it doesnt go below 30 degrees C. Can anyone help plsss
get the filters out wash them carefuly dry them and put them back,check if the liquid inside must be replaced by a expert ,service from time to time is required
Jan 07, 2013 | Heating & Cooling
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
I have a Frigidaire model GLFU206FWA upright freezer. The temperature control won't go above 10 degree F. This causes freezer burn on some foods after a period of time. Is there a way to regulate the...
Good day,
Manufacturers of freezers do not give the option of running the machine much above that temperature. Normal operating temperature for a freezer is about -2 to about 8 above F.
Otherwise people could accidentally set the temp too warm and cause a loss of food.
Some appliance parts houses carry universal thermostats that could possibly cover the temperature range your looking for, but 30 degrees is far to warm to preserve frozen food safely.
Jun 21, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Heater warms up in morning but over the day only gives cold air despite being set at 22degrees. VW dealership says when set at 22degrees it will warm up to 30degrees and then introduce cold air to bring...
vw fit 3 types of aircon,
1.full climate control (you set temp is stays there)
2.climatronic (as your dealer said.....)
3.aircon std (cold draft)
you cannot change whats fitted to another type.
Apr 08, 2010 | 2004 Volkswagen Eurovan
Not heating. The fan blows, but no warm air. RHEEM RCGA-60A1AS24
Please check if the compressor is running, if not, then
there is no warm air generated. Please contact the RHEEM dealer about it. Aircon compressors are run
with a thermostat. So, you may try setting the aircon
thermostat to maximum, so that the compressor run,
and you can have your warm air. May this info help you.
Jan 10, 2010 | Heating & Cooling
Can Movincool classic plus 26 AC set the air temperature at below 70 degree F?
aircons normally pull down to approx. 17 degree celcius.and heats to approx 30 degree celcius.  most of the time you need to simply clean the condenser properly and to make sure fans are in good order.
Oct 16, 2007 | Movincool Classic Plus 26 Air Conditioner
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
