Question about Humidifiers
Can I run my small cool mist humidifier without a filter?
2 Suggested Answers
  • 7 Answers
SOURCE: Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Posted on Feb 12, 2008
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
Dec 13, 2009 | Vicks Cool Mist V3500 Humidifier
WHY DON'T MIST COME OUT OF MY HUMIDIFIER
with cool mist humidifiers your not suppose to see any mist. if it's a warm mist there should be. but by your model number i'm finding that it's a cool mist. that's why your not seeing any mist.
Aug 15, 2009 | Vicks Cool Mist V3500 Humidifier
New filter,still no mist and water level does not drop
make sure that the filter is VERY snug into the bottom of the humidifier, and that the tank is on correctly. We had the same problem :)
Jul 01, 2009 | Vicks V3100 1.2 Gallon Humidifier
Humidifier not working
Ensure there is water in the tank.
  • This may be caused by mineral deposits in the water channels. Try the following: Clean the water tank, base and vapor nozzel with a damp cloth to remove any build up in the water channel.
  • When was the last time the cartridge was changed. (If it’s been over 3 months, this could be the reason why the unit is not working properly.)
  • Unscrew the demineralization cartridge and run the unit, if it starts to mist then you need a new cartridge. (insert cartridge link here)
  • The screw cap for the water tank, onto which one first screws in the demineralization cartridge, has a small rubber gasket. make sure that gasket is not too far down against the outer screw cap. If it is the spring loaded button would not work properly to let the water descend into the base tank .
    The solution: push up on that small rubber gasket so that it is as far up and away from the screw cap as it can be without falling off, and voila! you get mist!!
  • If you have changed the filter recently then take out the cartridge and run the unit without the cartridge for about 15 to 20 minutes.
May 18, 2009 | Venta Airwasher VS 207 3.7 Gallon...
Hi, I just recently purchased a Vicks Cool Mist Humidifier V400 Series. Could hardly wait to get it working. Problem,it did not come with the filter, box doesn't say not included. I have called around, and...
http://www.filters-now.com/products/uvk.html#UFK04=UVK
here is the website that you need to order the filter. the filter model number is k04. right now i'm seeing the filter as being 5.99 before shipping and handling. if you have any other questions please feel free to let me know.
Apr 19, 2009 | Vicks Cool Mist V400 Humidifier
Humidifier
I have the evenflo cool mist humidifier, model # 758100. There should be a model number on the unit. As far as replacement filters, you can buy the Holmes humidifier filter, model # HWF62. It's compatible with Evenflo. I bought a 2-pk at Target for $15.99. Hope this helps.
Jan 09, 2008 | Evenflo Evaporative Cool Mist Humidifier
Humidifiers Logo
127 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
