Question about HP LaserJet M3035xs MFP All-In-One Printer
Ready, data and attention lights flashing m3035
  • 4 Answers
SOURCE: HP 4350 printer
you might need to upgrade the firmware
Posted on Feb 11, 2008
printech
  • 159 Answers
SOURCE: blank display
If the printer control panel is blank when you turn on the printer, check the following items.
1 Make sure that the printer is plugged into an active electrical outlet receptacle that delivers the
correct voltage.
2 Make sure that the on/off switch is in the on position.
3 Make sure that the fan runs briefly, which indicates that the power supply is operational.
4 Make sure that the control-panel display wire-harness is connected. See the hint in the
procedure for Top cover.
5 Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again
Posted on Apr 05, 2008
  • 81 Answers
SOURCE: The printer has a solid green ready light, a solid
Try removing the jetdirect and power cycle the printer.
Posted on Oct 12, 2009
seeker5211
  • 1089 Answers
SOURCE: HP2550 problem:The attention light, the
According to your "secondary" light pattern your printer has a Carousel motor error.
You've already power cycled it to no avail.
The next step is to get the motor replaced.
Sorry, I know that you didn't want to hear that.
Posted on Apr 07, 2011
Testimonial: "Thanks so much for the analysis. I suspect you are right. And thanks so much for the rapid feedback. "
BaronVonNuke
  • 1915 Answers
SOURCE: My machine is powered up but the screne does not
The last time I ran into this problem it was a faulty formatter. Your first step is to remove the formatter and reseat any memory dimms or cards on the formatter. Always power off printer and unplug before removing/installing the formatter. If pirnter does not start after reseating memory, unplug printer again and remove formatter and start printer without formatter installed. Once you have powered up the printer, look for a small hole on the back of the printer, Upper left side if you are infront of printer, right side if you are facing the back. Use small object like paper clip to push the button which will generate an engine test. If it prints, then the formatter is most likely bad, but firmware on formatter may also be corrupt.
Posted on Jun 01, 2011
Printer 5550 laser color cood 59.c0
I am assuming you meant HP Color LaserJet 5550 Error Code 59.c0
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Sep 06, 2016 | Laser Office Equipment & Supplies
How do i fix a 59.C0 error on my printer?
  1. Turn the printer off, and then turn the printer on.
  2. If the error message returns, turn the printer off.
  3. Perform a cold reset.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence. NOTE: If this message persists, you will need to contact an HP-authorized support provider.
Sep 15, 2015 | HP Color LaserJet CM2320nf MFP Refurbished
Error Code 51.2 C on an HP 4600
This is a laser error. I found this directly from HP's website. Here's your fix:
  • Press the green c00224695.jpg (Select) button to continue.
  • Turn the printer off, and turn it on again.
  • Perform a cold reset.
    1. Turn on the printer.
    3. When the memory starts counting, press and hold the c00224695.jpg (Select) button.
    4. Continue holding the c00224695.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the c00224695.jpg (Select) button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  • If this message persists, contact an HP-authorized service or support provider. Please let me know if this helps you!
  • Oct 01, 2011 | HP LaserJet 4600 Printer
    Code ereur 59
    A code error 59:
    Description A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly. Action
    1. Press the green c00099346.jpg (Select) button to continue.
      3. When the memory starts counting, press and hold the green c00099346.jpg (Select) button.
      4. Continue holding the green c00099346.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
      6. Press c00099347.jpg (Down Arrow) button once. The control panel will display COLD RESET.
      7. Press c00099346.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
    Mar 02, 2011 | HP LaserJet 5550DN Printer
    Error 51.2 y hp color laserjet 4600
    Hi There, Please follow the below steps to fix this issue :
    Action : 1. Press the green (Select) button to continue. 2. Turn the printer off, and turn it on again.
    3. Perform a cold reset : a.Turn on the printer. b.Watch the control panel. c.When the memory starts counting, press and hold the (Select) button. d.Continue holding the (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady. e.Release the (Select) button when the Ready, Data, and Attention light are on steady. f.The control panel will display SELECT LANGUAGE . g.Press (Down Arrow) button once. The control panel will display COLD RESET . h. Press (Select). The printer will perform a cold reset and then continue its power-on sequence. 4. If this message persists, contact an HP-authorized service or support provider.
    Nov 08, 2010 | HP LaserJet 4600dn Color Printer
    A 51.2 error message means that there is an error 51(Printer Error).2 (Laser Error) C (Cyan). This basically means that there is something wrong with the laser and the cyan color laser.
    Reference via HP Website, Click Here
    To Fix the problem:
    1. Press the green c00224695.jpg (Select) button to continue.
    Mar 21, 2009 | HP LaserJet 4600 Printer
    Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
    10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
    Solution:
    Turn the printer off and then back on again.
    If error returns, remove all print cartridges and turn off the printer.
    Cold reset the printer:
    Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    Wait for the printer prompt to install each print cartridge.
    This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
    Jan 15, 2009 | HP LaserJet 4600dn Color Printer
    HP Laserjet 1320 Printer doesn't respond
    Manual Feed or Continuable
    Error
    This state can be reached in
    the following circumstances:
    ● Manual feed
    ● Out of paper for the
    specified tray
    ● General continuable error
    ● Memory configuration error
    ● Personality/Job related
    error
    Solution
    To recover from the error and
    print whatever data is possible,
    press the GO button.
    If the recovery is successful,
    the printer goes to the
    Processing Data state and
    completes the job.
    If the recovery is unsuccessful,
    the printer returns to the
    Continuable Error state.
    Feb 05, 2008 | HP LaserJet 1320 Printer
    HP LaserJet M3035xs MFP All-In-One Printer Logo
    201 people viewed this question
    Seeker5211
    Seeker5211
