Question about Dell Inspiron 530 Desktop Computer
Comp. powers on, shuts down three times then goes into powersave
My Dell Inspiron 530 desktop: i turn on the power button and the computer powers up, then shuts off, then powers up, then shuts off and the third time it powers up, it stays on and the screen comes up. after about a week or so of this behavior on the third attempt that it powers up, it stays on but the screen goes into powersave mode and i cannot access the computer.
I had a similar problem...I'd turn on my Inspiron 530 and it would power up and shut down by itself several times and then finally finish booting up but nothing would show on the screen.
Turns out, it was a bad video card. Since there are two ports for hooking up a monitor -- I ended up hooking up the monitor through the VGA and completely removed the video card (just used the built-in device on the motherboard). This solved the problem and it booted up straightaway.
Dell is sending the replacement video card and I will just use the built-in until it arrives.
I hope this helps with your problem!
Teachinfourth
Posted on Jul 19, 2009
  • 3 Answers
You may want to check the power supply fan whether it works properly or not. Also, you may need to check your BIOS setup if you had done anything with it.
Posted on Jun 23, 2009
No power in dell touchscreen inspirion replaced power cord and still no power the led light will not even come on
remove the power card and battery
hold down power button 30-40 sec
and now reconnect power card and check
try it 3 to 4 times
if not power on contact dell
Jul 13, 2012 | Dell Inspiron 530 Desktop Computer
Inspiron 530 desktop--- computer boots up, runs just fine for a while, then monitor displays gabled multi-colored patterns, then evetually shuts down.
What is shutting down, the monitor or the computer. Check the power light on each for proper diagnosis. You either have a bad monitor, a bad video display card or a bad PC, specifically a power supply or motherboard. This is a classic symptom of something getting too hot and shutting down. One way to test the monitor is to plug it into something else for an a period of time and test. If you're PC is shutting off, try unplugging unnecessary peripherals, i.e. CD/DVD drives, floppy drives, external USB peripherals, etc. Start with just the video adapter, keyboard, mouse and monitor. Let us know what is shutting off, for further diagnosis.
Aug 13, 2011 | Dell Inspiron 530 Desktop Computer
My Dell Inspiron 530 used to freeze up ever so often. I would have to manually shut it down and restart.After a while I found out that running the AVG scan it wont shut down so often.One day while booting...
This is a system fault error condition, including the power supply. Only the +5VSB rail on the power supply is working correctly.
ports to see if anyare damaged and then try powering on the system to see if you get a green power button.
Feb 23, 2011 | Dell Inspiron 530 Desktop Computer
My Dell Inspiron 530, works fine once its powered up, but it take three attempts for the computer to boot on. I have taken the following steps. Checked that all fans are operational, they are. I have...
OK, here is what dell says:
BIOS checksum failure. Possible motherboard failure.
Try re-seating your memory modules and see if the beep code disappears
Also, Try using the Dell Diagnostics which is located on a hidden diagnostic utility partition on your hard drive or on the Drivers and Utilities Cd that came with your computer.
  1. Ensure that the computer is connected to an electrical outlet that is known to be working properly.
  2. Turn on (or restart) your computer.
  3. When the DELL™ logo appears, press <F12> immediately. Select Boot to Utility Partition from the boot menu and press <Enter>.
Press any key to start the Dell Diagnostics from the diagnostics utility partition on your hard drive.
Dec 29, 2009 | Dell Inspiron 530 Desktop Computer
Dell Inspiron 530. Started shutting down on its own a few days ago, sometimes just completely shutting off, sometimes going through the whole 'logging off' and 'shutting down' process. Have tried a...
hello, i don't know from wher u can get a button but u can try somthing else; try to see if your cooler it is working properly ( look in bios and see what's your CPU temperature is after 15 minutes of working; if it is over 60-70 celsius degrees then u need to change the cooler)
Dec 28, 2009 | Dell Inspiron 530 Desktop Computer
How to shut down dell inspiron 530 computer - the button only takes computer to sleep mode
I assume you use Windows Vista.....
In vista the default action of the power button is configured to sleep mode..
So to shutdown the PC you can press "Start - right arrow - right arrow - right arrow - Enter", or you can navigate to the same using the mouse & selecting shutdown from the list besides the lock icon.
You can also change the power button configuration this way goto " Start-Control Panel-System and Maintenance-Power options-change plan settings (under the current plan you are using) - change advanced power settings - Power buttons and lid - Start menu power button" click on settings and select shutdown, apply & save the settings and close this window.
Now you can just click the power button to shutdown your computer.
Jul 05, 2009 | Dell Inspiron 530 Desktop Computer
Dell Inspiron 530 randomly shuts down and restarts
Sounds like it could be a virus. Or, a heat buildup problem - are all fans inside machine working? Is the fan inside the power supply operating? Was there any work done inside the computer recently?
If the hdw is all ok, go out and buy yourself a copy of Norton Internet Security 2009 - 1 user lic - $49.99 @ Staples. Do *not* buy any earlier vers. of this software! Install, update it, run computer computer scan - probably will find/remove some/many viruses.
If this helps, please take the time to rate my response to you.
Thanks and good luck.
gurutim
Mar 22, 2009 | Dell Inspiron 530 Desktop Computer
Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Mar 08, 2009 | HP Media Center m7060n PC Desktop
Dell inspiron 530s is giving me major trouble. When ever I turn it on, the power button lights up and the fan turns on but then thats it. There is no activity on the monitor, just the loud noise of the...
my inspiron 530 giving me trouble. Blue light is on, but the computer goes no where. Try to start by shutting down and restarting but the start sound keeps coming fora long time and nothing happens. So to say having trouble starting and sometimes it shuts down but the blue light stays on. Sometimes I cann't even turn off the computer by pressing blue light - trouble trouble trouble
Feb 22, 2009 | Dell Inspiron 530s Desktop Computer...
Dell Inspiron 530 Desktop Computer   Logo
705 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
