Question about ARB 4x4 Accessories ARB OMEFJCLK Old Man Emu Suspension Lift Kit
What is the sloution of bumby ride? - ARB 4x4 Accessories ARB OMEFJCLK Old Man Emu Suspension Lift Kit
Why does it always shut down when I come to a stop?
Sloution 1. Check your Idle Air Control Valve, clean it with carb cleaner.
Solution 2. Check the Mass Air Flow sensor if its dirt, if so clean it with Mass Air Flow cleaner not carb cleaner.
Sloution 3. Clean your throttle.
These 3 steps are likely to solve your problem, if not then the problem is bigger it maybe the Cam sensor.
Feb 13, 2016 | 2006 Opel Corsa 1.4
Rattle under car on a bumby road after replacing the conrol arm w/ball joint...2008 chevy cobalt
Exaust hangers or cactilatic converter heat shield would b a starting point
Mar 02, 2014 | Cars & Trucks
No sound
Sounds like the bumby road may have made ur output wires touch and short out some output transistors in ur amp. Or ur amp has bad solder connections. Either way have ur local repair technician have a look at it
Nov 16, 2012 | Kenwood KAC-9103D Car Audio Amplifier
Air ride leak back bags wont lift dont hear a leak tho please help to bumby for my 2 year oold son
Any errors on dash ? Get a manual ! Resolve any errors. Next check for sound that compressor is running...it should run after a few seconds of 'Key On-Engine Off'' if air bags have low pressure. It is located (underneath air filter... left front).. Check for defecctive air bags and their solenoid valves.
I found used replacements for all of these components on eBay.
Bozzjax
Sep 06, 2010 | 1994 Lincoln Town Car
2001 Grand Prix SE tranny trouble.
You can't use those two words in the same sentence when talking about transmissions. Best is new (rarely done) next is a rebuild (most times if from a good reliable shop, good but not cheap) then there is the used unit from a scrapyard..cheaper than either, but if it doesn't work, you get to pay r&r as many times as it takes, even if the yard guarantees it. (only way I'd do that is if I owned another identical car that I had driven and knew for sure the unit was good.
May 26, 2009 | 2001 Pontiac Grand Prix
Tire pressure
you will have a hard rite, your tires may wear down faster
so i will say yes!
G
May 05, 2009 | 2002 Suzuki XL-7
Dtc 525
please try by reinstalling the drivers.report back your findings
Apr 03, 2008 | Fargo DTC550 Thermal Card Printer
My N73 is not charging
try to replace ur charger, coz charger not compatible to your phone.
Feb 07, 2008 | Nokia N70 Cellular Phone
ARB 4x4 Accessories ARB OMEFJCLK Old Man Emu Suspension Lift Kit Logo
Top ARB 4x4 Accessories Clothing Accessories Experts
Da Doc
Tom Chichester
Are you an ARB 4x4 Accessories Clothing Accessory Expert? Answer questions, earn points and help others
