Question about Refrigerators
I have a 55L gear up camping fridge and it works great on on 12 and 240 but is not cooling anything on gas , thinking it might be the jet . But where would I buy one???
    Top Expert:
  • 3,698 Answers
Camping world or other RV places.
Posted on May 13, 2014
5 Suggested Answers
  • 51 Answers
SOURCE: dometic rv refrigerator
Does it switch automatically to gas if so the plug may be losing voltage on the back side were it plugs in. As you say the voltage is good I would then look to the eye brow control board inside the trailer or the lower control board outside as being the issue. It is hard without testing the board to tell witch one it is.
Posted on Sep 07, 2008
SOURCE: Chescold caravan fridge 3 way
Yep same prob as my Chescold model RC1180. I pulled the entire gas circuit apart as the fridge works well on 240v haven`t yet sussed the 12v.
I suspected the thermostat ( on the gas side ) there is a tiny jet on the side of the aluminium block at the base of the electric thermostat, also another springloaded 'valve' at the bottom of the aluminium block.The ' valve' is actuated by the thermostat Dial, as it screws a pin down onto a plate which departs from an O' Ring seal letting gas into the chamber where the tiny Jet is seated.This tiny Jet meters the gas to the Pilot burner.
Anyway ' That' wasn`t the problem! lol
The Problem was a 'Clogged Pilot flame Jet'
Fix..... I stripped as piece of fine electrical wire 12v and cleaned the jet out. It is a # 26.
The Jet itself looks like it has been 'Stamped' out rather than Drilled, this may account for some fridges working better on gas than others as there seem s to be some distortion on the Jet Orifice. I will buy a new Jet and a #26 drill and replace the original one.
I am just testing the fridge on Gas now...going like a Trojan... bonus is ive got a little 3 sausage hot plate over the Gas exhaust and am cooking dinner while the beer is getting colder !
K
Posted on Apr 12, 2009
VtToolMan
  • 704 Answers
SOURCE: Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Posted on Jul 30, 2009
richroth
  • 9472 Answers
SOURCE: Our Dometic RM 2611 fridge
make sure all your connections are tight. Check current draw (amps) at the incoming power (one wire at a time)there are no moving parts in it, so it has to be a loose or dirty connection. Unplug each wire coming off the circuit board and verify that the board has output and input. There is a schematic located in the compartment also. Here is a link to a service tip manual that may help you also.
Posted on Aug 09, 2011
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Dometic rc1180 not cooling down on gas
clean all LP lines to ignitor if no clicking replace board
Oct 25, 2012 | Dometic Refrigerators
My unit works great on AC (cools to 30degree), but
Your fridge has two manual settings to adjust it's internal temperature. Obviously, it most likely has a standard control (1-5 or 1-9 depending on the fridge) that you can adjust on the control panel. Some fridges are preset (no control panel adjustment) and must be adjusted on the inside of the unit. If open your fridge, look at your cooling fins. You will notice a metal slider on a wire attached to one of the fins. Moving this sensor up or down along this fin will set the internal temperature of the fridge. You will have to play with it a bit to get it set properly (with a thermometer), but you should be able to get it to the proper temperature. I hope this solves your problem. Thanks... John Charles
Jun 12, 2010 | Dometic RM2652 Refrigerator
Was camping all weekend... frigerator was fine, brought it home and plugged it in and all electrical works fine, but frigerator is dead. none of the lights come on (auto, off, gas) no cooling. How can we...
This can be a problem on the control board or in the control switch, you better check this first..
For clarification may I know what model/maker that you have?
Thanks
Aug 31, 2009 | Thetford Norcold RV Cooler/Freezer
Jul 26, 2009 | Dometic RM2193 Compact Refrigerator With...
Sudden lack of power. Doesn't sound or feel right.
I would change the gas out, you may have got some bad gas.
Apr 10, 2009 | 2005 kawasaki VN 800 Vulcan Classic
Chescold caravan fridge 3 way fridge, (out on the bench not in a van) works well on 240V but not on gas. Pilot looks good, fridge is level, I have tried inverting the fridge as suggested. No luck. I can't...
K
Dec 06, 2008 | Refrigerators
Electrolux camping fridge not getting cold when running on gas, warm air flows from top vent bottom vent not blocked please help
Does it work o/k on 120v? If it does then you may only need to have the burner serviced which entails pulling the burner and jet apart and giving it a good clean out. If the fridge heats up on 120v but does not cool, then you have a major problem with the cooling system and can be expensive to repair
Swy
Aug 25, 2008 | Electrolux Refrigerators
Bottom,(refrigerator) isn't cooling at all. the freezer is 20 below zero. what's wrong?
The thermister is located in the fridge. Verify it is clipped to the metal fin Think of this as a knob control move it up and down to control the fridge temp. If this does not help most likely you need a new thermister.
Jul 08, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
