Question about Boston Acoustics BA745 Computer Speakers
What are the power adapter specifications?
What are the power adapter requirements for DC power to the subwoofer?
    New Friend:
  • 3 Answers
Model: AD-1202000AU
Input: 120VAC 60Hz 300mA
Output: 12VAC 2000mA
what are the power adapter specifications? - power-adapter-specifications#-stntuvmdf0c1axxiekwforc3-5-0_0.jpg
Posted on Oct 22, 2014
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
Need specific default answer, not discussion
Check AC-DC adapter with a Voltmeter and compare DC voltage with laptop's stated voltage requirements. They have to match
Also try holding power button in for 1 minute in case laptop is frozen and then try powering it up with power switch.
A higher DC voltage than what your laptop states on the case will cause damage to circuits.
Jun 10, 2015 | Computers & Internet
I have a pair of acoustic research "active partner" speakers in need of a power adapter. Above the entrance of the plug in print it has DC 11.5 V. Need a compatible adapter.
DC 12v adapters are common and I think that would work. The similar "Powered Partner" speakers used a 14v DC adapter. Just check the size of the plug and the configuration (center pin is +). Radio Shack and other sellers have universal adapters.
Sep 29, 2013 | Acoustic Research Audio Players &...
How many volts is the power adapter
The speakers use a 10 Watt power supply
Sep 06, 2011 | Sony SRS-A37 Computer Speakers
I need a 15V AC to AC adapter for ouir Audio Source home theatre subwoofer. Can you help? I can easily find 15V AC to DC and the only 15V AC to AC power source cables I can find are for Toshiba...
Sure! An Audio Source Sub power adapter is $38 +$9 shipping from this seller. It's importnat to know the power requirements of the device in either watts or amps to choose an adapter capable of serving the load. Otherwise, it might be too small and cause a fire. This one looks like it is like the one supplied originally.
I hope this helped & good luck!!
Nov 01, 2010 | Audio Players & Recorders
Replacement AC/DC power adapter required in Malta or UK. Where can I buy ?
try to check in the electronic shop and get the specific rating of the original ac dc adopter.
Oct 14, 2010 | Televison & Video
Power adapter specification ct-630
Hi - look in back or under keyboard for power specs.Then go to Guitar Center and the right adapter. GuitarCenter.com has casio power adapters.
Jan 04, 2010 | Music
Dell power supply ADP-220AB B output schematic
It may be possible that your adapter does not receive the rated power it should receive. You may have plugged your adapter to a 110 v outlet when the required input is 220 volts. See your adapter for the specific requirements.
Oct 26, 2008 | Computers & Internet
Power adapter specififications for CANOSCAN N640Pex Color Image Scanner
scanner is on ant then scan documents but dont show image.it show multiply lines.
help me
Apr 08, 2008 | Office Equipment & Supplies
DC Power supply specifications
here is the info you need...
Input Power 100~240V, 50~60Hz
9V DC,1A Max
Hope this helps...
Feb 09, 2008 | Computers & Internet
Boston Acoustics BA745 Computer Speakers Logo
246 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
