Question about Coffee Makers & Espresso Machines
I own the Breville BES860 coffee machine. I try
I own the Breville BES860 coffee machine. I try set the finest grind to make espresso with the Dual wall and single wall filter but I found that the dual wall filter have crema but the single wall can't produce any crema. Why? Is that normal? What is the best grinding setting and best pressure to make a cup of good espresso? Pls help !!! Thks a lot!
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Weak coffee and pale crema.
If you get weak coffee from espresso machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on Apr 05, 2009
IbuyUSA
  • 9 Answers
SOURCE: crema light in color
Grinding coffee at a finer setting (stronger coffee) only speeds up the clogging effect it has on machinery. The finer it is the more it acts like mud. The oils in this mud cake dry up right after the water dries up (over night) and presto you have concrete! This concrete becomes to thick to clean, so cleaning with tablets has to increase dramatically if you increase the strength of the coffee. If you leave it strong clean it weekly.
Normally you clean the brew unit with cleaning tablets every time you finish descaling. That's about once every 200-250 coffees based on the water hardness you set in the electronics. If you notice changes in the coffee waterflow speed it's usually from clogging.
If you're handy get your camera. Take pictures of every step you do. Remove the brew unit. Disassemble the left top section (2 screws holding the long pipe). It compresses a 1/2" long spring. It may get away from you so be ready for it. The spring attached to a half round plastic button (valve) that looks like a rivet. Clean all brown gunk from this valve and the housing and you're creme will return. While your in the cleaning mode remove the filter and clean inside under the filter. The filter is that round stainless steel screen disc with the phillips head screw in the center.
All this is evedence that cleaning needs to be stepped up, good luck!
Posted on Oct 19, 2009
  • 219 Answers
SOURCE: With the BES860 set to Dual Wall for full
If your using the dial gauge with a dual wall basket, you need to leave the dial in the dual wall setting. If you move it beyond the dual wall setting, you are basically adding more volume to the basket. Leave it in the dual wall setting for dual wall baskets.
Otherwise it may be faulty, it could be your grind setting, try it on 13 and see how it goes.
Posted on Jul 29, 2011
BES860 GRINDER
IF YOU CAN TRY TAKING IT APART THERE MAY BE SOMETHING STUCK IN SIDE.OF A BLADE MAY BE LOOSE. OR TRY DOWN LOADING A MANUL FROM YOUR COMPUTER USING THE NAME OF PRODUCT THE MODLE NUMBER.
Oct 28, 2014 | Breville Fresca BES860 2Cup Coffee Maker
I can achieve normal pressure only by using dual wall baskets.
The grind is too coarse or the tamping is too light, or a combination thereof. Use some bathroom scales to get your tamping pressure right and then adjust the grind accordingly.
Jul 26, 2013 | Breville Fresca BES860 2Cup Coffee Maker
I just bought a Breville BES860 Fresca Espresso Machine and when I tried to put the basket into the portafilter, it doesn't fit. The portafilter came standard with the machine. Do I need a bigger...
They require a bit of effort to push them in when new, you should have gotten a set of single wall and dual wall baskets. There is a spring clip inside the grouphead (portafilter) and you have to overcome the clamping of the spring it is a reasonably tight fit to stop the basket retaining in the machine.
Jul 02, 2011 | Breville Fresca BES860 2Cup Coffee Maker
Brand new machine and the pressure gauge doesn't appear to be working, I've made about 10 coffees over the weekend and experimented with the tamping etc. And the gauge has not moved once? Am I...
It could be a faulty machine, what is your grind setting? Make sure your using the dual wall single cup as a test. Set the grind to around 13 and grind your own beans, don't use supermarket bought beans or preground coffee. Both are garbage.
Also if your using the dual wall basket, make sure that you leave the dial guage in the dual wall setting. Then tamp the coffee so it sits roughly 3-5mm below the rim, this is what I have found is best for this unit.
Then secure group head in to unit, press single cup and you should hopefully get a pressure reading, if it isn't going up you are under extracting and your grind is prob to coarse (correct me if I'm wrong), I've found 13 is not to coarse not to fine. Shouldn't feel like fine sand, when coarse but not powdery.
If the gauge does not move in to the grey area your unit is most likely faulty.
Jun 05, 2011 | Breville Fresca BES860 2Cup Coffee Maker
With the BES860 set to Dual Wall for full automation, even on the lowest auto grind volume setting, the grind volume is too large and it spills over. This is on double setting and using the double filter...
May 07, 2011 | Breville Fresca BES860 2Cup Coffee Maker
My coffee grinder is not working! the beans are coming out chunky and not in a nice fine ground espresso. What Should I do??? Is it clogged?
On the side is a dial, you need to adjust this to get the correct grind.
If they are chunky then you prob only have the dial set to low.
I have found that 12-13 is a good grind.
Dec 03, 2010 | Breville Fresca BES860 2Cup Coffee Maker
Grind size cannot be ajusted
On the side of the machine is a rotary dial, this adjusts the grind size. The other dial adjuster only increases or decreases the volume not the grind size.
Oct 20, 2010 | Breville Fresca BES860 2Cup Coffee Maker
Hi. On the Breville CG10 coffee grinder, is the higher the number the finer the grind or the other way? Thanks.
Yes, 1 is finest and 9 is coarsest.
From the manual: 8 - 9 Percolators 4.5 - 6 Espresso Machines - Steam System 3.5 - 5 Drip filter coffee makers 2.5 - 4 Espresso machines - pump system 1.5 - 2.5 Espresso machines - semi automatic pump system
Aug 21, 2010 | Breville Coffee Makers & Espresso Machines
Breville 800esxl
A card included in the operating manual indicates that this is normal. The Breville "Dual Wall Crema System" will do this. Visit www.breville.com for more information.
Nov 22, 2007 | Breville Die Cast 800ESXL Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
