Question about Lexmark X7170 All-In-One InkJet Printer
Hook up What wires and where. I just moved and need to locate my wires and don't know what they look like.
    Scholar:
  • 122 Answers
Need wiring help please
look up the wiring diagram from the manufacturer
this is your best bet
May 29, 2013 | Toys
My old thermostat had 4 wires connected to it, I have 5 wires white black ,blue,yellow and red. the wasn't connected to the old thermostat.Do i need to connect the red one to the new thermostat because...
locate the wires at the unit and hook them up in the same way . If it was not hooked up before you most likely don't need to hook it up now.. but check the unit where the wires connect to it.. let me know Have fun
Jul 24, 2011 | Heating & Cooling
Don't know how to hook up the amp. It came with a wiring kit and I have no idea on how to hook it up.
You need to connect the Power wire (Most likely red wire with fuse) to the battery and run it to where you put the amp. You need to also drill a whole in the car and make sure it is grinded up and bare metal is shown. Screw the ground wire there with a bolt and nut. You will then need to run the rca cables from the amp location to either the back of the headunit if it has RCA outputs, or use a Line out converter, you can get them at best buy. Then you need to find your cars wiring harness code and figure out which is the remote ignition turn on and tap into that and feed that wire back to the amp to turn it on. Hook all wires up and make sure power and ground DO NOT TOUCH.
Jul 24, 2011 | Visonik Dual Bass Box with Amplifier Car...
How to hook up a telephone. I need to know how to hook up a telephone from the box outside to the phone jack inside.
In order to do that you need to know on which pair does your phone jack inside your home is connected. In case you don't know or it is not connected then you need drop wire and punching tool to connect. Simply ask your service provider on which pair he has connected connect the drop wire on the same pair and extend it to your phone jack with drop wire.
Jun 30, 2011 | Lands Phones
Now power to the trailor hook up on back bumper, fuses are O.k. wiring apears to be o.k. it is dodge ram 1500 4x 4 single cab c/w 4.7 8cly. be nice to get a wiring diagram. thanks Wayne
you will need to check the wiring under the bumper where the trailer wiring is with a test light and with the different lights working.you will probably have to move back in the wiring by 6" and retest until you find were the loss of power is.you don`t say if all the lights don`t work or just certain ones.the brown wire is the tail light,green is the right signal light,yellow is the left signal light and white is the ground wire.you could have broken wires at the trailer hook up itself.
Mar 22, 2011 | Dodge Ram 1500 Cars & Trucks
Stereo Wiring Colours
2006 Ford Focus Car Stereo Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 11, 2010 | 2006 Ford Focus
The system was removed to another location and one
Yes it could. It sounds like your low voltage wires are not hooked up properly. You need to get your contractor back out there.
Joe
Sep 30, 2009 | Broan-NuTone CV353 Central Vacuum
How to remove front bolts in Mustang GT electric seat when it is stuck all the way forward and covers bolt heads?
Once I had this problem and had to strip the wires under the seat and hook them up to another power source ((Your Battery)) Find the wire that moves the seat back and strip the wire, then hook it up to a seperate wire leading to the battery ((I used jumper cables)) If successful the seat will move back and you'll be able to remove your seat.
Aug 12, 2009 | Ford Mustang Cars & Trucks
STEREO WIRE CODES DIAGRAM FO A 1998 BUICK CENTURY
need codes to hook up radio to 1999 buick century
Aug 22, 2008 | 1998 Buick Century
Lexmark X7170 All-In-One InkJet Printer Logo
64 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
