Is soniq e42s14a active 3d? - Televison & Video
How can I use headphones wit a Soniq S55UV16B-AU Smart TV?
You have to use wired headphones and plug them in.
https://www.jbhifi.com.au/tv-home-entertainment/hd-televisions/soniq/soniq-s55uv16b-55-uhd-smart-led-lcd-tv/316772/
Component Inputs - 1
RCA Inputs - 1
RF Input - True
Headphone Output (3.5mm) - True
Energy Star Rating - 3.5
Product Height with Stand (mm) - 782.7
Product Width with Stand (mm) - 1240.6
Soniq S55UV16B
Sep 23, 2017 | Televison & Video
SONY BRAVIA 3D ANDROID TV MODEL-43W800C 3d active or passive in bangladesh? Which 3d glass required?
A 3-D glass won't be effective; especially in Bangladesh. A 3-D mirror; which look like a (kaleidoscope) is needed to see images in 3-D; in your country. Look for that.
Jul 04, 2016 | Sony Televison & Video
Soniq E42S14A stuck on the Cinavision screen and the remote wont change it back to the full screen
Do a hard reset, and check. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. Gopakumar Gopalan Google
Feb 10, 2015 | Televison & Video
How can i convert 3d split screen to half sbs so i can watch 3d movies on my soniq E55S148 3d tv
I would suggest you know what you're talking about first
SBS means side by side It's not 3D SBS is a format to be used in conjunction with virtual reality headset/ goggles
If its HSSBS half screen side by side that you mean then that is for viewing on a small hand held device and you still need the VR goggles
So if you are downloading actual SBS you can't split it
If its HSSBS the file is too compressed to view on a TV
If its 3D format you need a 3D TV and use the 3D glasses
You can however use software to convert SBS to 3D format whilst its stored on the device you downloaded it to but when you play it on any TV it will have no 3d effect even with glasses
So until you sort out if its SBS or 3D you haven't got a hope
split screen 3d or simul view is only really meant to support two player games
More importantly you shouldn't have been such a cheapskate and invested in a proper TV Soniq uses a mix of branded and Chinese components that aren't 100% compatible so no amount of add ons ?or software upgrade will convert that piece of junk to anything that is capable of playing SBS HSSBS or 3D
If you want good quality adult movies you should pay to join a reputable site but if you choose to download pirated p?r? you can only expect to get what you pay for
My question for you is if you wanted to watch SBS why did you download in 3D and then want to convert back to a format that is not 3D?
Feb 03, 2015 | Cell Phones
Does my Sony kdl55w829b 55 inch HD 3D Smart tv have a built in 3D transmitter to use with the active 3D glasses ? If so how do you activate 3D viewing ?
This TV has the active 3D transmitter built in to it in some regions. It is included for the model sold in the U.K.
You need to register the Active 3D glasses before they will work with the TV. To register the glasses, turn on the TV and bring the glasses within .5m of the TV. Then press and hold the power button on the glasses for 2+ seconds (until the power button blinks alternating green and yellow). When the registration is successful, a message will show on the bottom of the TV and the green light will stay on for 3 seconds. This will need to be repeated if you use the Active 3D glasses with another TV and then use them again with this TV.
Now you need to activate the 3D feature on the TV. Press the 3D button on the remote or press the control bar on the Touchpad remote and slide the touch pad to the 3D icon and select it. Then choose your 3D option. You may also need to adjust the 3D display settings from the Home button. Press Home and select Settings. Then choose Display and then 3D.
The manual for the KDL-55W829B is available here: http://www.sony.co.uk/support/en/product/KDL-55W829B . The Help Guide, http://download.sony-europe.com/pub/manuals/tvhc/14HE468112-EN-Print.pdf , has the information on using the 3D feature starting on page 56.
I hope this helps.
Dec 19, 2014 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
Urc codes for soniq e19z10a
There is no code for Soniq with this remote control.
Aug 29, 2012 | Televison & Video
How to activate tochflo 3d in touch diamond phone
download 3d touch from the net and install it
Jul 18, 2009 | Computers & Internet
Remote code for Soniq TV
Only code I could find is: Soniq 1497 1328
Nov 28, 2008 | Directed 434MHZ Remote Control
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
