Question about Dell Latitude D600 Notebook
Not charging when the charger cord is in
Not charging
  • 184 Answers
Check the charging cord for possible breaks on the cable. get a meter or go to a technician and test for continuity on the cord. if that is okay, check the charging port and be sure you have a proper contact or that the port is not burnt out. also check the adapter if it is still supplying power from the source. else you may look at the battery if it is still good.
Posted on Jun 23, 2009
    Scholar:
  • 122 Answers
You either have bad power transformer or a bad opwer receptacle on the laptop.
You can test the power supply with a multimeter. If it gets the correct voltage, your receptacle on the laptop is broken. Repair requires replacement of the motherboard, and probably will not be cost effective.
Repairing Charging cord on Braun shaver cord
no--simply because there are live wire connections to the transformer that people will touch and then seek compensation for that carelessness
best if you junk it and simply buy a new charger
Jul 10, 2016 | Braun Syncro 7526 Electric Shaver
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
My charger is loose so I need a USB charger where can I buy one
try amazon if you are looking for just the cord.
Nov 10, 2013 | Tablets & eReaders
MH-25 is not charging the battery
Check the cords and make sure to disconnect and then reconnect the cords. Try the charger if nothing then try replacing the battery. If the battery is bad the charger will not work. If the battery is replaced and will not charge then replace the charger.
Mar 26, 2013 | Nikon MH-25 Charger NIKON
My gateway netbook wont charge, they sent me a new battery but again it will not charge, what could be wrong?
The problem might be either from the charger or from the laptop.
To confirm and repair if it is the charger, all you have to do is to plug the charger on another laptop to see if it will charge, if it does not charge, then you know the fault is from the charger, and the solution is for you to replace it with a new one, before you replace it, try to connect another power cord to the charger, because sometimes the power cord might have been burnt, that have happened to me twice and replacing the power cord solved the problem. But if replacing the power cord does not help, then you need to change the power cord.
To confirm and repair if it is the laptop, plug in a new charger to the laptop, if it does not charge, then you need to understand that the charging port of the laptop is faulty and needs to be replaced, have a repairman replace the charging port for you.
Take care and good luck
Oct 31, 2010 | Gateway LT2021u Netbook
Fuji battery charger BC-45 - red light blinks when I put in battery and battery does not charge
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Aug 03, 2010 | Duracell AA/AAA NiMH Battery Charger with...
CHARGER
u can use USB cord to charge for temp only dont use usb cord for charging for long time
Jun 24, 2010 | SVP Xthinn 8061 Digital Camera
MP3 Wont charge or upload
u need a new cord for charging.u lost ur receipt so no problem u can buy it any electronic or computer market i hope.
Aug 03, 2009 | SanDisk Sansa Clip MP3 Player
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Dell Latitude D600 Notebook Logo
107 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
