Question about Flowtron Bug Zapper Bulb
How to wire a bug zapper - Flowtron Bug Zapper Bulb
Should my 1.5 acre stinger bug zapper zap when I plug it up
Intuitively, I glean it zaps when you turn it on only if you are a bug. Zapping is caused by the bug encountering the zapper. Otherwise, it would zap you even if you were not a big bug, simply because you were in close proximity.
Aug 20, 2017 | Air Purifiers
Why is my bug zapper not zapping bugs?
no high voltage being produced
have it checked out or buy a new one
May 24, 2016 | Air Purifiers
I have a flowtron bk-2125 bug zapper, looking at the troubleshooting, it said check for power on the grid, how do i do that. I changed bulb and it is not coming on, it said if i have power then the starter...
If you have no power from the grid then bug zapper is not problem. If bug zapper is a corded plug in application then unplug and plug into a plug in that you know works. Check your breaker panel for a tripped breaker and reset if necessary. Or try a different appliance by plugging something that you know is operational into the same plug. If it works, there is likely an internal problem in bug zapper.
Oct 08, 2014 | Cars & Trucks
When installing the two required C batteries into my new Stinger bug zapper. In what manner should the batteries be inserted into the battery compartment ?
Not sure which model of Stinger bug zapper you have. If you are using C batteries then it could be a portable racket zapper.
Please check model number and compare with list of manuals on this site.
Owner Manuals StingerProducts com
If there are only two batteries then there are 4 ways in which these can go. You could try and see which one works.
Sep 03, 2014 | Camping, Backpacking & Hiking
How to repair
Is the buglight still working? I simply take a blade of grass and place in between the wire cages to make electrical connection and verify transducer is not defective. If you don't get a spark quickly your transducer may be burned out as I cannot keep one working due to larger insect getting in unit and overloading the transducer.
May 22, 2014 | Stinger 1 Acre Bug Zapper
I heard some clicking noises and sounded like a bug in bug zapper. should i unplug it??
yes . it sounds like the main board . the clicking would be the relay that starts compressor ... change the main board .. mm feed back pls . with a model # i can give you part # & price .
Oct 22, 2010 | Hotpoint Refrigerators
Green light is on, fan is blowing but we know longer smell the ozone from it; we have just changed the plate & cleaned it?
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
Apr 18, 2010 | Ecoquest Living Air Classic Air Purifier
I have a CMZ984 coleman portable rechargeable bug zapper.I have lost the manuel and charger for it.It is 4 watts.The company that made it for Coleman has gone out of business.It is about 2 years old.What...
The CMZ984 takes 6 volts DC at about 850 ma or 0.85 Amp. The problem is finding a plug that will attach to the Coleman charging port. Use the Radio Shack universal DC power supply. This is a little unit that comes with an assortment of plugs and has a number of switches on the Radio Shack DC power supply. (1)-Find a plug inside of the Universal DC power supply that fits without forcing, (2)-set the voltage to 6 volts and (3)-the polarity to "+". When the universal power supply is plugged into the bug zapper and the universal DC power supply set at 6 volts, turn on the BUG ZAPPER. If the lights inside turns on when the battery is dead then you probably have all switches set correctly. At yard sales, this UNIVERSAL power supply sells for about $1. It comes with a number of different plugs. Don't forget to write the voltage and polarity on the bottom of the bug zapper for the next time.
Jul 29, 2008 | Kitchen Ranges
Flowtron Bug Zapper Bulb Logo
46 people viewed this question
Top Flowtron Home Experts
Donni Steen
Tom Chichester
Are you a Flowtron Home Expert? Answer questions, earn points and help others
